LCD Burn in?
Old Jan 24, 2026 | 05:47 AM
Mike Lowrey's Avatar
Mike Lowrey
Default LCD Burn in?
What's going on here? It's slowing starting to fade away but I've never seen this happen before.
Old Jan 24, 2026 | 08:48 AM
M3Inline6's Avatar
M3Inline6
Yikes! That’s something I haven’t seen occur in a 992 before. Maybe that LCD screen is starting to fail rather than it being a burn-in issue. It takes soooooo long for true burn-in to happen, IF it ever does.
Old Jan 24, 2026 | 09:58 AM
NiteJav's Avatar
NiteJav
Are you dealing with extreme cold? Maybe the LCD is struggling with the temperatures?
Old Jan 24, 2026 | 10:04 AM
dixonk's Avatar
dixonk
Veteran: Army
When you switch the car off is the screen blacked out or is a pattern visible? On my C2S in the past I had similar looking screen twice. Both times it went back to normal after switching off the car overnight.
Old Jan 24, 2026 | 10:13 AM
Mike Lowrey
Not when this happened.
It was still visible when off and today it was visible yet faded.
Old Jan 24, 2026 | 10:43 AM
woobiee's Avatar
woobiee
This has randomly happened to me a handful of times on my 2022 and resolves itself every time. Sometimes it takes just one power cycle, other times it takes a couple days.
Old Jan 24, 2026 | 10:52 AM
rob944s2's Avatar
rob944s2
Might be a programming bug, the previous screen still showing after not being cleared from the display / memory. Could also show when the car is “off” and the screens go black but aren’t yet truly powered off.
Old Jan 24, 2026 | 01:38 PM
dixonk's Avatar
dixonk
Veteran: Army
Pull the negative battery terminal and let the car sit for a couple hours to fully discharge.
Old Jan 24, 2026 | 02:53 PM
Mike Lowrey
It resolved itself. I'll let y'all know if it comes back.
