I have a problem with my headlights. (Car is a 2024 Targa 4 GTS)
I replaced the headlights to new ones (ECE PDSL+) control modules are the same (once we tried but only the right one and it seemed functional), and now when I turn on the ignition, low beam turns on, and nothing else is working (no high beam, no daylight, no indicators) and the lamp cannot be turned off.
In the fault codes section I can see "SOA mismatch", and "invalid dataset" fault codes in the LED control modules (left and right).
Do you have any idea what I can do?
Did you *upgrade* to PDLS+ from base PDLS, or are you just replacing preexisting PDLS+ units due to crash damage or some other reason? If the former you will definitely need to recode the car with PIWIS to accept the upgraded equipment. If the latter they should drop in with no changes.
The original was also pdls+ based on the features of the car.
And I replaced them because of a crash.
We found the solution. My problem was that the rule files for the led control modules and the bcm1 were missing from piwis and the auto code function cannot work.
