PPF Headlights 992.2?
Old Oct 28, 2025 | 01:00 PM
adrianp89's Avatar
adrianp89
The only reason to take off the PPF is because it's damaged. If it's damaged that means the headlight would have been damaged without it. In the very rare chance removing the PPF damages the headlight, it's net-zero since you would have to replace it anyway from the damage.
Old Oct 28, 2025 | 01:14 PM
RatherJaded's Avatar
RatherJaded
PPF has a self-life of approx ten years max on a vehicle that sees very little UV. Expect 5-7 years on vehicles that regularly see UV. Even if the film is not damaged it will eventually have to be replaced.
I am witnessing a good bit of hood rock chips on the 8 mil Xpel Ultimate Plus film so I would expect the same would occur on headlights covered with the same product. Best advice, pay the additional money for the 10 mil film.
Old Oct 28, 2025 | 01:41 PM
rasetsu's Avatar
rasetsu
Originally Posted by Motorin Mark
Just thinking out loud here. My PFF guy was also adamant about not PPF on Porsche headlights due to delamination, thus mine do not have PPF on them and far so good, but lets say if a rock hits my headlight and cracks it badly enough to need replacing, wouldn't my collision or comp insurance cover the replacement of my $7K headlight? Kind of a different topic for sure, just wondering.
Yes, your insurance SHOULD cover. But you still have to pay the deductible and there is no telling what your insurance may do to your premium come renewal.
Old Oct 28, 2025 | 03:00 PM
adrianp89's Avatar
adrianp89
I've never heard these numbers. I've heard stuff on old school PPF but nothing on the new stuff. My truck is going on 6 years and still is great (minus damage spots)
Old Oct 28, 2025 | 03:18 PM
RatherJaded
Xpel warranties their films for 10 years. At one time 10 mil of film thickness was the standard. Now 8 mil of film thickness is the standard and 10 mil costs additional $.
Edit: Cars that are often tracked or see a lot of highway use will greatly benefit from the 10 mil film.
Old Oct 28, 2025 | 04:27 PM
Fixinbones's Avatar
Fixinbones
I've driven 50,000 miles in a 992.1TT and a 991.1 TT in crappy NY roads in winter as well and have not had any significant chips in my headlights.
Old Oct 28, 2025 | 04:34 PM
MoeMistry's Avatar
MoeMistry
Premium Sponsor
turn them on at night, but only if you want to see what cannot be unseen 😎
Old Oct 29, 2025 | 09:49 AM
jezzaa's Avatar
jezzaa
I just removed my 3 year old headlight ppf easily without any heat gun or steamer.
going to replace it with a new one because the old ppf turned yellowish and hazy with some small marks.
ppf on headlights are cheap to replace. Just replace them in regular intervals
Old Oct 29, 2025 | 09:58 AM
MoeMistry's Avatar
MoeMistry
Premium Sponsor
the curvature of 991/992 headlight is aggressive and I highly recommend letting a professional install/remove
If DIY wishes to attempt, steam is HIGHLY recommended for successful, consistent, and desired outcome
quality films won’t yellow or crack if cared for properly with a ceramic coating and routine cleaning/protecting
I caution removal of ANY ppf without proper technique
Old Oct 29, 2025 | 02:38 PM
adrianp89's Avatar
adrianp89
Warrantied for 10... much different then it needs to be replaced at 10 years.
Old Oct 29, 2025 | 02:43 PM
ace_pilot's Avatar
ace_pilot
Anyone on Long Island that can do PPF on the headlights? Mine would not do it.
Old Oct 29, 2025 | 03:51 PM
RatherJaded
I grant you if one is parked out in the sun and in the elements for the majority of every day then one will need PPF replacement prior to the ten year warranty expiring. Having worked in the automotive industry I have seen it personally. As stated the average for most individuals is approx 5 to 7 years. Take note that removing PPF at 10 years or older, a lot of PPF installers will not want to take the liability risk of removing it and if you can locate an installer whom is willing to take the risk, expect to pay $150-$200 an hour to remove it.
Old Oct 29, 2025 | 06:36 PM
adrianp89's Avatar
adrianp89
I see this argument a lot. I get it. What it lacks is the advancement in the film. Older stuff like 3M used heavy adhesive, cracks easy, and is brutal to remove. Xpel comes out with better and better stuff all the time. What is true of PPF in 2017 is not true of PPF in 2025. Frankly the really good stuff is only a few years old so no one knows what it will be like in 10 years.
Old Oct 29, 2025 | 09:39 PM
jezzaa's Avatar
jezzaa
I am sure this is sound advice and I probably got some level of luck facing a problem free and easy removal.
Old Oct 30, 2025 | 11:49 PM
RolexSub's Avatar
RolexSub
I PPF'd all my headlights for all my cars and it saved me a few times from large rock chips. I rather replace the PPF again then getting a declaration on my vehicle for $7000.
