Aerokit and FAL
The hydraulic pumps are around $500 normally, the controllers and switch panels should be around $250 each - the lines are probably $500 new from dealer if you can't find them used. Depends on your platform - GT3 shocks are normally around $1,500 each - other around $500 each. . . . The nice part about this is it's OEM, and you will have access through the OEM interface and PCM - plus smart lift GPS memory.
I would never consider after market for this - way better to retrofit OEM.
Rodents damaged lines on the pump/accumulator. The dealer told me that Porsche didn't sell the individual repair parts and they had to install a complete new unit. Since I hadn't actually seen the damage and since, fortunately, my insurance was footing the bill I didn't argue too much but MSRP on just the pump/accumulator unit was almost $10K. Yes, that's right...$10K.
I told them to return the original unit to me and, upon inspection, I determined that the single chewed line could easily be replaced. From the markings on the hose I was able to track down the original English source, ordered a section of the hose for about $30 including shipping and repaired the returned one myself. The car is gone but I still have the pump...if anyone is interested.
