Post actual weights / savings on 992 options with source here
Old Jan 11, 2026 | 12:24 PM
  #61
Tobeit's Avatar
Tobeit
Not sure if this was already said in this threads.
rear seat removal (none leather):
bottom cushion 6.5lbs
rear back rest: 6lbs each
seat belts/buckles: 5lbs (all parts for the pair together)
so, a little over 23lbs saving.
Old Feb 3, 2026 | 11:43 PM
  #62
repcapale's Avatar
repcapale
Does anyone have actual weights of the Porsche mag wheels?
All I can find is weight savings from the regular wheels.
Old Feb 5, 2026 | 07:13 PM
  #63
REVS11's Avatar
REVS11
Well, in the CTE thread @REVS11 posted weights for his CTE CCB’s. It’s a 14 lb. reduction for each front rotor and he still has to weigh his OEM rear GTS rotor, but the reduction for each rear rotor should be similar. So weren’t looking at an estimated 50-ish lb. overall weight reduction by going with carbon discs.
ST rotors give you a larger weight saving but it comes at a huge premium.
ST 14.2 vs CTE 18.6 lbs front (used stock 408mm 32.5)
ST 400mm 14.3 vs CTE 390mm 16.4 lbs rear (used stock 380mm 23.7-24.7)
So with ST rotors you remove 36.6 + 20.8 = 57.4 lbs. (weights checked with bathroom scale on flat steel workbench)
CTE uses higher density materials both in the rotor and the hat, Stopflex also mentions using higher density carbon than ST.
Old Feb 5, 2026 | 07:45 PM
  #64
M3Inline6's Avatar
M3Inline6
That’s great info. The ST’s are double the price of the CTE’s, so that’s definitely a factor.
Old Feb 5, 2026 | 08:25 PM
  #65
REVS11's Avatar
REVS11
^^^ this
Hinz found me the one replacement rear ST rotor I needed so now I have both ST and CTE setups... Seems like I need to add one more 992.
Probably will run the sturdy CTE rotors on track and ST rotors on street.
Old Feb 5, 2026 | 08:41 PM
  #66
M3Inline6's Avatar
M3Inline6
^^^ this
I am curious to get your on-track CTE feedback.
Old Feb 6, 2026 | 12:04 PM
  #67
Mr.Gonz's Avatar
Mr.Gonz
Worth mentioning that for the S guys with 350mm brakes, instead of going the CCB route I simply had caliper brackets fabbed to be able to run 380mm 911 GT3 CUP rotors from Paragon (72 vanes). The fronts are the exact same weight as the oem, and the rear are just 3lbs heavier. Very good brake upgrade for almost net zero weight gain on steels discs, and significantly cheaper than CCBs.
Old Feb 6, 2026 | 12:08 PM
  #68
Mr.Gonz's Avatar
Mr.Gonz
BRE Inconel 3" Turbo Back exhaust (lightest valved exhaust option on the market): -33.8lbs
Old Feb 6, 2026 | 12:53 PM
  #69
M3Inline6's Avatar
M3Inline6
Where did you source your Paragon discs?
Old Feb 6, 2026 | 03:16 PM
  #70
Fullyield's Avatar
Fullyield
Weight savings with exhaust and cats, I assume?
Old Feb 6, 2026 | 04:56 PM
  #71
prodigymb's Avatar
prodigymb
what brackets did you use?
Old Feb 6, 2026 | 06:45 PM
  #72
CJDCREW's Avatar
CJDCREW
That’s… a lot of savings. I’d love to see some details. I’ve heard great stuff on BRE so not throwing shade on them at all, but for comparison, the Kline 70 mm Inconel valved cat back for 992.1 Carrera/T/S/GTS (not saying lightest or best) is 15 lb vs OEM 27.5 lb and the Kline 200 cel inconel cats are 10.5 lb vs OEM at 15 lb which gives a full Kline system a 17 lb weight savings. Twice that reduction is hard to get my mind around having seen and held these, unless you are not valved and not running cats? Curious, I love some good weight savings. I don’t have 17 lbs to lose on my body unless it’s a limb I prefer to keep.
Old Feb 6, 2026 | 06:54 PM
  #73
Fullyield's Avatar
Fullyield
Agree. I am pretty sure that weight savings figure includes sport cats or catless which is why I asked above.
JCR Titanium valveless non-silenced
Old Feb 7, 2026 | 04:17 PM
  #74
Mr.Gonz's Avatar
Mr.Gonz
Key word is turbo back.
From the turbos back.
So it includes the downpipes / link pipes.
The BRE Valved center section weighs 12.3lbs
The downpipes weigh 3.4lbs each (no cats).
And these are the custom 3" weights, the standard 2.75" sizing might be even less.
Old Feb 7, 2026 | 04:20 PM
  #75
Mr.Gonz's Avatar
Mr.Gonz
Also, I happened to get my hands on a Meisterschaft Valved Catback exhaust in Titanium.
For fun I weighed it, and it came in at 14.4lbs, so excellent value for money exhaust system in my opinion considering the weight savings, tone, and pricing. It's the standard 2.75" size so will bolt to factory or aftermarket downpipes easily.
Will be listing it for sale soon if anyone is interested in the classifieds section. PM if you want to frontrun that.
