@CJDCREW What are your factory options that your car weighs ~3,400 lbs stock? Strippers are supposed to be 3,250...
Weighed my 992.2 base this morning. 3,400 pounds, same as the 992.2 T. This is with 14-way seats, full leather, solid sunroof, no FAL. Steel brakes and no RWS (because neither of these are an option on the base).
I think I'll start a thread asking for people to share pix on scales. I think it'd be interesting. Hell we've got one just for pix of cars at gas stations so this has got to be more useful.
2025 992.2 Carrera 2WD base with ~11 gallons of fuel, solid sunroof, no FAL, no RWS, steel brakes, 14-way seats, full leather.
Public weigh stations aren’t very accurate. I’d bet both cars are slightly less.
3,400lbs for PDK, sunroof & heaviest seat option makes sense.
But what is the spec on your T that would make it 3,400lbs?
MT alone should be a huge savings over PDK. Although, it does have a mLSD & larger brakes. Assuming you spec’d the same options (sunroof & 18-ways/rear seats). I’m surprised.
A typical (non-GT3) 992 weighs in somewhere around 3500lbs. The T-hybrids weigh a bit more than that. My 3 pedal 991.2 Targa weighs less than my PDK 992 C4S did.
These aren’t lightweight cars and the weight savings achieved through various option choices is de minimis. If the heart wants carbon fiber wiper arms, go for it, but you’re not going to get a 992 lighter without dramatic steps that compromise street ability or safety.
To be fair, I don’t exactly have a stripper even though I’m having fun dieting it. I guesstimate I’m +120 lb from the OEM T 3254 spec.
24 MT, extended range tank at 80% fuel, 18 ways with the T fabric (back trouble), back seat (wife demand), Bose, Carbon fiber roof (vanity), extended leather, FAL (debate not needed, my driveway is impossible and my wife loves the house) and RWS. I probably had about 10-15 lbs of “stuff” in the car when it was weighed (max) AND full PPF, some Moshammer bits, and mine came with the lead acid so was always going to be at least + 30-ish compared to the quoted T weight which is IIRC on a 24 - no FAL, no RWS, no extended tank, no rear seat, 4 ways, no sunroof. I’m confident in my swapped parts weight savings math, though I’m sure a scientific scale would show minor differences, the scale is fairly accurate and consistent. I forgot to weigh it before I messed with it, but my swag says it should have been @ 3370 with my options before I started changing it. By my calculations, it should have been @3305 after the diet with a full non-extended tank, I came in at 3311 with a fuel guesstimate of @ 17 gallons so I’m within a modest % error on my forecast.
GT3 is another matter.
I have one on order. It is a significant improvement over the .1 and the right spec plus a few tweaks puts it within a stone's throw of an S/T.
Yeah, you get it, but it depends on what mountain roads we're talking about.
On a twisty mountain road, even with PDCC, AWD, and PDK advantage, a 500 lb heavier .2 4GTS is at best going to be on part with my .1 T, same driver.
You just can't hide that kind of weight delta.
Of course the GTS is going to gap the T on straights and what you describe is exactly what I always say: you drive the T on the gas and the GTS, even the .1, on the brakes.
Everyone has their preferences and everyone is in different stages of sports car ownership arc but after owning high powered cars, going fast in a straight line is boring to me.
I much rather spend my time hustling a car to speed than getting somewhere fast only to get on the brakes. Properly spec'd, the T is much better than numbers suggest.
I always appreciate your thoughts. You’re not wrong. Capable driver can do magic and it’s likely more important than outright power esp on canyon driving roads.
I love reviews like this because at least it’s apples to apples all encompassed in the same review. But now that the Turbo S is out, I wonder if people wouldn’t just get that instead of the GTS. Because 2 turbos > 1 turbo. And the truth is, I don’t know many drivers who choose between a GT3 and a Carrera T. Most GT3 owners I know would likely own both. It’s my truth that I see.
I’ve owned the 991.2 Carrera T and spent significant time in the 992.1 Carrera T which I wanted to love. It’s my opinion, but it left me wishing I had the manual with S/GTS power. I appreciate that Porsche makes the Carrera T, but it would drive me nuts (I’m not an ECU tuning fan but I get that massive appeal because it addresses my key complaint).
I don't know where the expectations of the T being significantly lighter than a standard Carrera come from. Here's Porsche's slide on the 992.2 T vs base, claiming a massive... 26 pounds lighter. And this slide is unclear if the carbon buckets are in that savings, but the "standard equipment" for the T is rear seat delete, while the base includes rear seats in standard equipment. Andreas Preuninger said in a GT3 992.2 launch video the rear seats in the GT3 Touring (which seem to be identical in all 911s) only add about about "6kg" (13 pounds). So add those back in and the T has only saved 13 pounds. Porsche intentionally doesn't list the low weight savings of deleting the rear seats, as it I'm sure saves them a bundle when people opt for plain thin carpet instead of nicely upholstered leather thinking they're doing themselves some great weight savings. I like a beautifully upholstered "rear trunk" myself.
I love the lightweight concept but pulling everything that makes the 911 a nicer place to be than a Caterham trying to make it into one defeats the purpose. I love my T, but so far the lightweight glass has already broken on me once and caused me to add windshield PPF, so I''d have taken standard glass if it was an option.
From the .1 era. Base is 3,340 vs 3,250 for the T. @detansinn is correct that the average Carrera excluding .2 GTS is around 3,500.
Your T makes sense with your options at 3,400. Same goes for @CJDCREW's car.
Unless you've gone through the exercise of removing weight from a car, most people don't realize how quickly you can add 100 lbs in options.
Most don't care. A few of us do. There's a reason why with few exceptions, the most iconic Porsches are all lightweight models.
Nobody will be able to tell my car has lost 300 lbs and my interior doesn't exactly look like that of a Caterham.
The 4way manual seats are probably a very efficient way to lose weight as well. I really like them, even with some back issues, never needed any further adjustments.
This car will soon become exclusively a road trip car so I may stick with these seats instead of upgrading to buckets.
Love my Macan Turbo with 18-ways, but sports cars need manual seats IMO.
Agree. I've sat in my neighbor's 991 buckets...beautiful but very impractical. I know myself and I think they would absolutely dissuade me from using the car more.
