well, the fact that in four years you didn't think to install them, even though you already tried them, says a lot!
You gave me an exhaustive answer,
thanks Stevelev
I primarily drive the car with the top down so the buffeting hasnt been an issue; however, you could always add them if your use is different than mine
By flush you are meaning the small space along the bottom?
It's something I would probably notice when I put in but after that probably wouldn't see it
Yes, that small gap at the bottom. I dont even think about it anymore after installing it. It doesnt cause any whistle or other noise and doesnt seem to leak any water into the door.
Yes, same. I don't even noticed the deflectors on my car now that I've put them on.
Can anyone give me more detailed information on how to remove the inner window trim piece? I purchased these for my 992.1 and I have tried with no luck to get wiggle and lift up the passenger side triangle. It will not seem to disengage, and I also slid under a trim removal tool as well as flat head screw driver. I just feel like the amount of pressure I was applying should be plenty and I dont want to break this thing. TIA
Odd that it won't come up. I think that might have been the easiest part of the process for me given that the buffeter pieces don't fit precisely. I just followed the online vids and they pried up pretty easily.
Having installed the AWE product. Use the thin/flat trim tool on the most front (towards fronk) part of the inside triangle trim and pry up while pulling the trim piece back towards rear of car with modest pressure. Yes, it feels like you may break it, but having done it 5X, never broke the plastic catch..
Just steady pressure with the trim tool. note the configuration of the plastic latch one removed and it will help with the removal of the second one.
It should be noted from my very close observations, that the AWE product does NOT fit flush with the rubber barrier to prevent water from leaking into your door. This is shown as a gap at the bottom of the AWE diffuser compared to the stock trim piece. If you look down the door once the stock trim piece (outside) is removed, you can see the rubber seal that the stock trim contacts to prevent entry of water (wash and rain). I have some concerns.
doors are designed to handle some water getting into them, dont stress
I wonder if they fixed them, because although I got them to fit on my 992.2 they were definitely not a perfect fit. The screws on the inside needed some finagling/man-handing to get them to line up
AWE-Tuning's kit does fit my 2026 992.2, and it does work... til about 105mph.
At Road Atlanta, if you get a good run out of T7 you're easily doing 160mph by the brake zone for T10a and after 125mph the buffeting is so bad it's literally dangerous.
Is the Fabspeed or another kit (I don't need CF) better in regards to working at a higher MPH?
you drive with open windows at 160mph on the track? May I ask why?
