LED Matrix Activation
Old Jul 14, 2025 | 06:38 AM
  #31
vinnysca's Avatar
vinnysca
Originally Posted by cutlass476
What battery maintainer/charger did you use?
I bought the Clore Automotive battery maintainer. It is around $530 bucks. It is heavy duty and some might say overkill. But it has great features and can charge both AGM and lithium ion batteries for vehicles. And you can literally set the continuous voltage to any car and operate any of the car’s electronics without starting the engine such as ECU flashing or reprogramming for the matrix headlights (the voltage can’t drop below a certain voltage or it may cause damage to the ECU while in flash mode).
Old Jul 14, 2025 | 10:53 AM
  #32
rp718's Avatar
rp718
How long does the reflash itself take?
Old Jul 14, 2025 | 02:33 PM
  #33
cutlass476's Avatar
cutlass476
Veteran: Navy
I just ordered the Clore PL-6100. It offers 60/40/10A charging and up to 100A at 13.1v-16.9v. Output voltage is programmable. I think you bought the big brother. I'm guessing the PL-6100 should be sufficient, as I should be able to program the output voltage to 13.9v or more at either 40 or 60 amps. I cannot imaging needing more than that.
Old Jul 14, 2025 | 08:03 PM
  #34
vinnysca's Avatar
vinnysca
If I remember correctly, it took about 30 mins
Old Jul 14, 2025 | 08:09 PM
  #35
vinnysca's Avatar
vinnysca
Yea, that should be adequate for flashing. Plus, you'll appreciate it when you want to recharge your battery in your car if it's been sitting too long. Or, any battery for that matter. Now you need to buy the dongle that is recommended. Then he will give you a link to the software so he can remotely control your laptop and he will ask for a VENMO payment and set an appointment for reprogramming. Oh, you need a windows laptop btw. I am a MAC user and I had to buy a windows laptop. I don't think a MAC with Windows app will work.
Old Jul 15, 2025 | 01:19 PM
  #36
pjjameso's Avatar
pjjameso
Question
Asked my club expert and he said that even after flashing we still don’t have the full matrix functionality as in Europe. Reason being that the larger ballast is not included in the USA cars which is required for each led to act independently.
What is the groups opinion on his comments?
Old Jul 15, 2025 | 03:20 PM
  #37
cutlass476's Avatar
cutlass476
Veteran: Navy
Based on the videos that have been posted by US members who have had this activation, the club expert's opinion would appear to be incorrect. The activated LED Matrix lights seem pretty impressive. If they aren't fully activated I cannot imagine what additional tricks they perform.
Anecdotally, I don't see Porsche manufacturing separate light housings within the LED Matrix light option. They might, but it would not seem to make financial sense to go the expense of specifying US and ROW ballasts for the same light housing.
Old Jul 15, 2025 | 04:06 PM
  #38
jlegelis's Avatar
jlegelis
Completely false. The headlamp and controller part numbers are the same world as wide, while driving videos from Europe match those of US activations.
Old Jul 15, 2025 | 04:08 PM
  #39
cutlass476's Avatar
cutlass476
Veteran: Navy
Wink Booyah!
Well, there you have it folks. Speed Racer calls BS.
Old Jul 15, 2025 | 04:22 PM
  #40
jlegelis's Avatar
jlegelis
Calling 'BS' only because I went deep down a wormhole converting my car from PDLS to Active Matrix, which to my knowledge hadn't been done previously, writeup here, so I definitely 'know too much' on this topic.
Old Jul 15, 2025 | 05:14 PM
  #41
cutlass476's Avatar
cutlass476
Veteran: Navy
Just busting your *****. LOL! I appreciate those on this board who have spent the time and effort to research something in depth, determine the actual facts, and then share what they've found so that everyone might benefit. Thank you, because now I don't have to go down a rabbit trail hunting for the info.
Old Jul 15, 2025 | 05:15 PM
  #42
pjjameso's Avatar
pjjameso
Thumbs up
Thanks for the info…now to get up the nerve to mess with my incoming 992.2 4 GTS! And of course find someone to do it……
Old Jul 15, 2025 | 06:09 PM
  #43
mda's Avatar
mda
@pjjameso I suggest reaching out to @rnlst_log
Old Jul 16, 2025 | 01:01 PM
  #44
Earle's Avatar
Earle
I successfully followed @jlegelis excellent instructions and with the programming expertise of @rnlst_log converted my PLDS to Active Matrix LED+. I leveraged @jlegelis knowledge of 'knowing too much', I really appreciate his efforts, it made my conversion super easy!
Old Jul 16, 2025 | 04:55 PM
  #45
nscodr's Avatar
nscodr
7th Gear
What software was needed for remote control and who would I DM if I wanted to enable LED matrix on my car?
