Max miles
911s like miles and they are better cars when you enjoy them as cars. Letting a 911 sit is abuse.
@politeperson has 60K miles
Pdk had been around for years…
Turbocharged flat 6 has had plenty of time work out any kinks…
Not too much electronics…
Still not electrified…
I think this generation will last a long time as long as well maintained
A well maintained 992 will easily do 200,000-300,000 miles on the original drivetrain.
I had two clients who kept theirs for years from new.
They went from cars to being classics!
One was a 993 that ended up with over 200,000 miles on the clock. It was a bit sun faded but otherwise fine.
The other one was a 997 with 160,000 miles on the clock, same thing.
I thought keeping it was cooler than changing it every 3 years or so.
What other car could do that?
Apart from the oil and filter changes, it has has the accessory belt, brake fluid, plugs, a PDK oil change and that is about it.
Brakes have about 40% left, tires average 16-20,000 miles a set.
No PPF, the paint is still as new apart from 2 pin chips on the nose cone and a bit of gravel rash on the rear quarter clear plastics panels in front of the rear wheels.
The interior is still like new, even the piano black.
Oil consumption is zero and it still drives like new.
No point in changing it.
2002 986 100,000 miles daily driver, snow tires in winter, no issues that I would consider out of the ordinary.
2013 981 Cayman only 65,000 miles ( i retired ), again no issues to speak of. Got PPF on the bumper and hood, and it certainly helped keep the car looking good
Currently looking for a 992.2 to get that experience. If maintained, which I’ll admit is not cheap, they will last.
I know of many 911's with over 75K miles...some with over 100K miles. If you maintain the car as it should be maintained, then all you need to do is drive and enjoy. However, you start tuning and whatnot - then you can expect a shorter mechanical lifespan.
