Car cleaning question
Old Oct 13, 2024 | 08:21 PM
jmrichards's Avatar
jmrichards
Default Car cleaning question
Porsche conveniently places a ppf shield on the rear hips of the car to protect the paint. I recently turned onto a road I drive regularly, only to find it partially repaved. The grit and tar from the road surface stuck to the ppf, and does not wash off with the usual car soap. Any suggestions for cleaning the ppf without ruining it?
Old Oct 13, 2024 | 08:25 PM
Bxstr's Avatar
Bxstr
Pic of it? If the PPF is chipped, the only way to solve is to remove the PPF. I recommend a larger piece in place of the factor piece.
If it was just in the PPF, it's possible that tar remover could work. https://www.carpro-us.com/daily-deal...x-500ml-17-oz/
Old Oct 13, 2024 | 09:30 PM
GTorBUST's Avatar
GTorBUST
WD40 is my favorite, or 70% isopropyl, or 3m adhesive remover
Old Oct 13, 2024 | 09:31 PM
woobiee's Avatar
woobiee
Clay bar should do the trick
Old Oct 13, 2024 | 09:44 PM
Shambler's Avatar
Shambler
I use the rinseless XPEL cleaner.
Old Oct 13, 2024 | 10:59 PM
m732sg's Avatar
m732sg
Carpro Tar X or equivalent. Watch a few videos on application.
Old Oct 14, 2024 | 10:59 AM
Staffie Guy's Avatar
Staffie Guy
All you need is a product called Goo Gone. I have been using it for years to remove tar, grease, glue residue, and other gunk. Spray it on and wipe off- goo is gone.
Old Oct 15, 2024 | 07:59 AM
kilyung's Avatar
kilyung
Word of caution. Goo Gone and Goof Off are not the same product so be careful. Do not use Goof Off without first testing somewhere inconspicuous.
Old Oct 15, 2024 | 08:53 AM
maschinetheist's Avatar
maschinetheist
Simple Green aircraft formula should be able to get it off
Old Oct 15, 2024 | 01:09 PM
Risley's Avatar
Risley
Be VERY careful with Goo Gone, it can damage many plastics.
