Thoughts on the Sport Response button
#31
CanAutM3 (08-16-2024)
#32
ok, I finally gotta ask (at the risk of the 3 or 4 guys on here that flip out and insult)... but what the hell is the big deal about 'sports chrono'? I have it which is basically just a digital clock with an analog second hand sticking out of my dashboard.... Why is it so desired and talked about? I does nothing.... I mean, I understand it has some feature to kind of determine speed around a track if you're accurate enough to turn it on and off when you start and finish but I assume most of us don't track the car and it's seems to be an awfully inaccurate measure of time if you have to pick the start and stop time yourself by pressing some button on some screen while also trying to drive.... what am I missing about this clock called sports chrono?
#34
#35
#36
My understanding is on 992.1 cars where sport chrono is an option (it's standard in our Ts), if you didn't select the sport chrono clock you wont have launch control or sport plus mode, and no mode dial on the steering wheel, maybe no individual mode either. I think in previous generations it was also how you got rev matching in a manual but I dont think thats the case in the 992 since sport chorno was included free with manual. 10+ years ago in the days of 991 and 981 when I was less into Porsche I would hear people say that it's an important option to have especially for resale, but seems to me like these days it ends up included in most cars just because it's in the sport package. as for the clock itself, not sure anyone uses it beyond "yep that car has sport chrono"
#37
I don't understand what this means.. I don't know what UTC is and it can't be accurate in time if it requires the driver to press start and then stop when he hits a finish line.... But I'm sure I just don't know this part of the car world... I have other cars with 'track telemetry' or 'lap time' features etc but they never made sense to me either.
#38
No, it is not.
Changing the engine speed without changing the load on the engine does not alter the turbo speed. All that the SRB does is put the engine in the powerband by downshifting the PDK while putting the engine in its most responsive Sport+ control algorithm..
The power and torque may not be higher than usual even at maximum throttle, but it is available immediately due to the preload. This is achieved by downshifting in PDK and thus increasing the engine speed, which raises the speed of the turbocharger due to the increased volume flow, which is then used to quickly build up boost pressure with the wastegate closed accordingly or activation of the VTG guide vanes. The ignition is then selected in such a way that there is no excess power at first, but once the accelerator is opened for overtaking maximum performance becomes immediately available. Boost pressure is maintained then during the 20 sec. period even when applying the brake pedal.
#39
From the Carrera-S configurator and press release:
The following 2 users liked this post by CanAutM3:
adm63 (08-16-2024),
F8T and 911T (08-16-2024)
aggie57 (08-16-2024)
#41
Agree. SC was in my opinion implemented for NA cars to keep them in the powerband. Pretty sure this option didn’t start till 997. Not necessary for Turbo cars
adm63 (08-16-2024)
#43
Changing the engine speed doesn't alter turbo speed inherently, but I'm pretty confident that drive modes (including both SRB and sport plus) use some wizardry to keep the turbo spooled while off-throttle. I assume it's pushing _just enough_ load through the motor to keep the turbo a little closer to boost rather than going to zero load like a mechanical throttle cable would. You can tell this is happening in sport plus in my car -- you can hear the turbo stay spinning when you let off after a bit of hooning around, and after a few seconds (5? 8?) there's a bit more engine braking and the turbo whine diminishes more.
#44
If you're on track already hooning around over the last 30 seconds, you're right - SRB makes no difference. But if you're on the highway crusing in Sport Plus and then you hit the SRB, the car downshifts. It is obviously not identical to Sport Plus in all conditions. (That said, SRB does not provide overboost or more power, or anything more than Sport Plus would if you're already driving at track pace).
The engine response algorithm, achieved through throttle mapping, ignition timing, valve timing, wastegate control, etc, is definitely different in Wet, Normal, Sport and Sport+; that’s the whole point of making those modes. My point all along is that SRB on the 992 is not some sort of magical button the provides additional power or an “overboost”. It just downshifts to the most optimal gear for acceleration and puts the engine in its most aggressive response mode.
#45
