Drive Mode Stuck on Individual in Dash
Old 06-18-2024 | 10:43 AM
PSPorsche's Avatar
PSPorsche
Default Drive Mode Stuck on Individual in Dash
​​​​Has anyone experienced this before, and what was the resolution?
The right hand dash display panel on my two month old 2024 C4S with the Sport Chrono package is stuck on the "Individual" drive mode.
The dial on the steering wheel does change the actual drive mode, and I can see the changes reflected in the PCM display.
Regardless of the actual drive mode selected, the digital display in the dash does not rotate away from "Individual". Another symptom is that the map view indicates "map is not available" (or something to that effect). The Tire Pressures are also not available.
Otherwise, the display functions normally, and other information is shown and changes as expected.
When I started the car this morning, "Individual" was preselected (which is the last mode I had used about four days ago when I last drove the car). As you know, the display should always default to "Normal" whenever you start the car.
I tried stopping and restarting the car, but that did not help.
Any ideas?
Old 06-18-2024 | 11:14 AM
MrOhnoez's Avatar
MrOhnoez
Bring it in for service. I've never heard of that.
Old 06-18-2024 | 12:03 PM
jlegelis's Avatar
jlegelis
If you have access to PIWIS there's a very strong chance there are stored codes or the controllers aren't fully talking. Often clearing the faults will resolve.
Old 06-18-2024 | 04:23 PM
PSPorsche's Avatar
PSPorsche
I do not have PIWIS.
I am going to try to reset the PCM to factory settings, and see if that helps.
I have a sneaking suspicion this is a side effect of the embargoed chip that had to be replaced prior to delivery. (But may be I am being too cynical).
Old 06-18-2024 | 05:14 PM
PSPorsche's Avatar
PSPorsche
Just started the car, and now it is miraculously working. I hope the problem doesn’t come back!
anjizkit (06-18-2024)
Old 06-18-2024 | 05:25 PM
Res Ips's Avatar
Res Ips
Good. Glad to hear it
Quick Reply: Drive Mode Stuck on Individual in Dash
