Is Mobil 1 Spercar oil a C40 oil?
Old 05-25-2024, 05:41 PM
vern1
vern1's Avatar
Default Is Mobil 1 Spercar oil a C40 oil?
I have a 2021 S coming in Mon and been doing a bit of research before I get it. I understand it takes a 0W40 C40 oil but although i have been googling and searching here for 40 mins I still cant find a straight answer. It is not on the bottle or box or any Mobil spec sheet
I have 3 cases of this stuff left from my vette and want to use it if its the right spec.
Anyone know or can point me where I can find out?
Old 05-25-2024, 05:42 PM
vern1
vern1's Avatar
Damn "Supercar" oil
Old 05-25-2024, 05:52 PM
null
null's Avatar
Have you looked at the spec sheet from Mobil?
https://www.mobil.com/en-us/passenge...upercar-series
It does not show Porsche C40 among approvals.
Compare this to their ESP X3, which does.
https://www.mobil.com/en-be/passenge...1-esp-x3-0w-40
If it's doesn't show the approval, I'd expect it does not meet the spec.
Old 05-25-2024, 06:04 PM
TK42ONE
TK42ONE's Avatar
https://static.nhtsa.gov/odi/tsbs/20...32392-0001.pdf
List of C40 oils from NHTSA
Old 05-25-2024, 06:09 PM
dudeoverthere
dudeoverthere's Avatar
This is the Mobil 1 oil you are looking for. Says C40 on the back. Advance auto parts should have it. Some don't though.
pal (05-26-2024)
Old 05-25-2024, 06:24 PM
vern1
vern1's Avatar
Thanks, I saw that but didnt show if it was C40 or A40 so figured it just didnt have that info
Originally Posted by TK42ONE
Thanks, I didnt find that but clearly lists only the ESP
Looks like I will have 3 cases of oil for sale, damn. Will have to order some ESP for next change. Thanks
Old 05-25-2024, 07:30 PM
nyca
nyca's Avatar
This came up on a previous thread - it seems even some dealers (like the Penske dealers) do not use the C40. Look for the threads - personally I would use what you have unless you can easily sell it.
Old 05-25-2024, 10:58 PM
F8Driver
F8Driver's Avatar
The C40 is necessary for the particulate filters in the exhaust. The 2021 should not have them and then the A40 IIRC will be fine. There are several oils out there that meet Porsche spec. I'm a fan of Liqui Moly. Generally speaking, any high quality synthetic in the range of 0-5 W 40 will provide ample protection for the engine well beyond warranty.
Old 05-25-2024, 11:10 PM
vern1
vern1's Avatar
So the 2021's dont have a particulate filter and dont need a C40 oil?
I can prob sell it as lots of guys looking for this oil for their vettes
Old 05-26-2024, 12:18 AM
pal
pal's Avatar
Looks like Motul x-clean gen2 is also C40 certified, and it says on the bottle too. I’ve liked Motul oils on my cars, and would want to lean towards this vs the Mobil1 ESP X3. Both seem available on Amazon too.
What do people think?
https://a.co/d/9Wjh3QP
Guzzgreg (05-27-2024)
Old 05-26-2024, 06:49 AM
Fullyield
Fullyield's Avatar
Received 1,502 Likes on 937 Posts
It is not just the particulate filter as discussed in the previous thread. I will only use the Porsche specified and approved C40 oil but especially while car is under warranty. You need a API - SN Plus oil (or C40) because of LSPI and TGDI. A40 oil does not meet the new standard hence the new formula and recommendation. Search Lake Speed and LSPI on YouTube.
Old 05-26-2024, 10:51 AM
vern1
vern1's Avatar
Thanks. I will just onload the Supercar stuff and get some ESP.
Fullyield (05-26-2024)
Old 05-27-2024, 03:32 PM
siberian
siberian's Avatar
Received 2,319 Likes on 1,378 Posts
This has been discussed extensively a few years ago.
I did the a lot of research and a write up (use the SEARCH tool), given my then impending oil change, spending quite a bit of time with LiquiMoly engineers since at the time only dealers sold Mobil1 0w-40 X3 ESP. As I mentioned then, you have other alternatives depending on where you live.
I use LiquiMoly 5w-40 C40 which limits me to driving at temps above -20F. I can use one of their additives to provide further protection for deep colds (we had -52F this past winter) but just drive my Touareg or Macan for those colder temps since both run on Mobil1 0w-40 A40.
For those not in cold climates 0w-30 C40 is fine.
The key factor (whether you have PF or not) is C40 compliance not viscosity. Thus its preferable to be C40 compliant than 0w-40 for 992s. If your local auto parts store doesn't carry Motul or LiquiMoly you can order from FCP Euro since they don't insist on FedEx or UPS shipping.
HTH
siberian
Old 05-27-2024, 05:39 PM
vern1
vern1's Avatar
Thanks. As mentioned, I did a pretty extensive search but didnt find your thread.
My 992 had the oil changed but the place I am getting it from without me knowing (apparently do this for all their sales). Found out it was with LiquiMoly A40. Talked to the service tech at the local Porsche dealer and he said yes, the C40 is the recommended oil but dont sweat it. Put the C40 in next change
Old 05-27-2024, 06:15 PM
siberian
siberian's Avatar
Here are a couple of my posts on the subject:
https://rennlist.com/forums/992/1259...-thread-2.html
(specifically post #17)
https://rennlist.com/forums/992/1251...-c40-x3-4.html
siberian
vern1 (05-27-2024)
Quick Reply: Is Mobil 1 Spercar oil a C40 oil?
