Rattle from rear headliner
Just took deliver of ‘24 TTS. Had a 1,000 mile home from the dealer and noticed a rattle coming from the back seat.
I searched the forums and many people reported rattles from the rear seatbelts, that’s not the case for me.
I tracked it down to a rattle in the rear headliner. If I stick my hand up and apply pressure to the rear headliner while driving the sound is gone.
While searching Rennlist, I did come across a post of someone who had a similar rattle and found that a clip meant to attach the headliner to the roof, was not attached.
I did have the dealer install cameras in the car and guessing they lowered some of the headliner so they had more room to work.
I climbed in, what I guess is called the rear “seats ”to see if I could get a better look at anything. I am not a huge guy, but trying to do anything in the backseat is nearly impossible. I ended up just pushing up on the headliner at random locations hoping to get luckily, I was unsuccessful.
Does anybody know where approximately the clips are located on the headliner? I tried to look between the headliner and the roof and can’t see anything obvious…
I am sure the dealer would take care of it, but they are 12hrs from me.
Do the clips run along the exterior edge of the headliner, where the roof meets the rear window? Or are they further inboard?
The sound seems to be coming from the rear middle of the headliner (very close to where the camera is installed).
Bonus points if anyone has a diagram of the clips on the roof….
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
https://rennlist.com/forums/992/1307...ky-rattle.html
084runnerltd (04-30-2024)
That clip is dead center at the very back. Stick your hands in and pull down slightly and you will see. It's some small dual lock clip. They don't like to be removed and put back and if it's not inserted perfectly straight the prongs will break. The part is $4 from the dealer.
Thanks in advance.
Thanks in advance.
