Reverse Camera Distortion
That is like saying the water is not really that wet - its just super normal for a water type of element... And by definition fisheye just means 180° field of view, which can be accomplished with anywhere from about 17mm down to 7mm - and that is a lot wetter of water ;-)
That SAID... It isn't the use of the fisheye that makes this unusable, its the "not use" of appropriate correction and the alignment of FOV between all the cameras... There are somewhere near 4-6 different perspective between all the views which makes it very tricky for the mind to understand relative distance all around the vehicle
Porsche is very - very, very good at cars,
Porsche not so good at the ancillary technical stuff that makes the modern cars more practical
