CUP2 tires recommendation
Old Mar 28, 2024 | 12:30 PM
pman3's Avatar
pman3
Question CUP2 tires recommendation
Hi, I've read dozens of threads here, but I still can't answer my dilemma, so I'd be extremely thankful for any help.
I'm driving my 992 Turbo pretty hard on mountain roads - good asphalt quality and I'm pushing it to the limits only when it's warm (e.g. my avg gas usage last 800km was ~40l/100km = 5.88 mpg). This is my daily car and Im driving it when it's raining as well, but then I'm careful and mostly driving in cities and with city speeds. I've got Pirelli PZero now, but I wanted to upgrade to something better. I started looking for Michelin Pilot Sport 4S N0, but I just learned they are not available for 992 Turbos, only for regular 992 (it's a different size of tire). It's a bummer, because they look (based on reviews) like something I want. I started considering CUP2 instead, but now I see they have different homologation ratings - N0, N1, N2, N3, and also there is "R" model, but this seems extremely track focused. My question is – what tires would you recommend. If I want to try CUP2, which "N" number should I chose?
Best,
pman3
Old Mar 28, 2024 | 01:02 PM
null's Avatar
null
The number following the "N" represents the version of the tire (higher the number, newer the iteration). If this matters to you, get the tires with the latest version number.
Old Mar 28, 2024 | 01:38 PM
CanAutM3's Avatar
CanAutM3
That is not entirely true. Each number is specific to a specific chassis application. The higher the number means that this specific tire is for a more recent chassis, but not necessarily the appropriate one. One should preferably pick the number for the right chassis application.
For example, in the PSC2 265/35R20-325/30R21 sizes I use, the N0 spec is optimized for the 918 Spyder while the N2 spec is optimized for the 991.2 GT2/3RS.
Old Mar 28, 2024 | 01:44 PM
CanAutM3's Avatar
CanAutM3
OP, I have the same car as you and run the PSC2 in 991.2 GT2/3RS N2 spec. The tires have a slightly wider nominal width than the TT OE tires at 265 front and 325 rear but the tread itself is significantly wider. My 992 TT is my daily driver and I drive it rain or shine. I’ve experienced no issue daily driving the PSC2 even in heavy rain.
Another option would be the 992 GT3 N0 spec PSC2 which are same 255/315 stock size as the TT. Both, the 991.2 GT2/3RS or 992 GT3 tires will fit the base turbo wheels, but they are a better fit on Exclusive Design wheels that are 0.5” wider front and rear and are a better match for the GT3 wheels for which the tires are optimized for.
The PSC2R is definitely too extreme for the daily drive and will suffer a fair bit in wet weather. Further, they seem to heat cycle out rather fast, so far from optimal for daily use.
Old Mar 28, 2024 | 02:28 PM
Angryinch's Avatar
Angryinch
IF you want something that heats up faster and provides better turbo grip, Nankang AR1, they are amazing and do not throw rocks as bad as cup2s.
I could not get cup2s to hook up well, they take a decent amount to warm up, especially if ambient is low.
Old Mar 28, 2024 | 04:17 PM
pman3's Avatar
pman3
@null @CanAutM3 @Angryinch Thank you so much for the responses, I appreciate it a lot!
@CanAutM3, interesting! I did not know that. I don't have exclusive wheels, if I knew they are wider, I'd probably take them I like the idea of having a wider tread, do you know if the PSC2 in 991.2 GT2/3RS N2 spec. You've written that on exclusive-wheels the fit will be "better", so, hmm, what could happen if my fit is "worse" I can't ask Porsche dealerships, they don't know anything about it, at least here ... @Angryinch I was thinking about Nankang AR1, but I've read they are really bad at rain, worse than PSC2. This is still my daily driver, and I would be concerned about it. What do you think? Regarding ambients - my ambient temperature when doing spirited driving is in the range of 10 - 30 Celsius degrees (50 - 86 Fahrenheit), but mostly in the mid-upper range of that.
Old Mar 29, 2024 | 11:01 AM
gthal's Avatar
gthal
I was worried about my Sport Cup 2 tires in cold/wet weather based on everything I've read but they are no issue. My GT3 is my daily car in Spring/Summer/Fall most days (Canadian weather). I've driven with them around the city in temps as low as 2-3 celcius and in rain when the ambient temperature was around 6-10 celcius. No issue at all. In that weather I'm not pushing the car hard but they didn't feel any different than PS4S tires. On the highway in rain, I just slow down a bit and watch for standing water. If you drive the car in wet or low ambient temp weather like you would on a 30 degree celcius sunny day, you might have an issue. If you drive in less than ideal weather with some degree of common sense, the Sport Cup 2 tires aren't an issue. Below freezing might be different
Old Mar 31, 2024 | 10:18 AM
Richard_Wallace's Avatar
Richard_Wallace
I agree common sense goes a long way.. However running Cups in wet, cold, etc. etc. as a daily normal situation will eventually end in disaster. They do not stop as well in wetl, hydroplane easier, compound is more brittle when cold, etc.
It only takes 1 second to find out why Cups are one of the best warm weather, not wet tires - and when it happens it will be unexpected.
Old Mar 31, 2024 | 07:23 PM
pman3's Avatar
pman3
@Richard_Wallace Thanks for the reply, which worried me a lot.
Uh, so what options do I have? Are Pirelli PZero the only option here? According to my Porsche Dealer, only tires I can get for my car (992 Turbo with 315/30 and 255/35 tire sizes) with 911 homologation are Pirellis and Pilot Sport Cup2. There is no homologation of Pilot Sport 4s for 911, and according to my friends from Porsche Center, installing ND0 homologation (for Panamera) would result in bad handling, as these tires are designed to handle engine placement differently. I will be driving this car daily, sometimes as today – I just did 1000 km between Spain and Portugal, unfortunately in heavy rain, straight for 10 hours of driving. I could be careful with Cup2, but if it "eventually end in disaster", then I don't want to do it. But also, I'd like to have better grip than Pirellis, especially when doing spirited driving when it's warm. Maybe my request is just undoable, but if anyone has any hints, please share them Thanks!
Old Mar 31, 2024 | 07:30 PM
pman3's Avatar
pman3
Edit: I also found that there are Michelin Pilot Sport 4 (NOT 4S, just 4) with N0 homologation (e.g. here: https://www.pneuslider.pt/pneu-auto/...1-105y-1424872) . Would they be better than Pirellis PZero for spirited driving? I know I sound like a noob, but in this topic I am one, and unfortunately, when Im trying to chat about it with my dealer, people they tell me they don't know anything about tires, they can only check for me availability of a model I will provide them with.
Old Mar 31, 2024 | 07:41 PM
Angryinch's Avatar
Angryinch
I find the Perelli’s to warm up a bit quicker than the cup2s. Both are good tires you can’t go wrong with either.
Cup twos are a little bit more sketchy when it’s cold out and raining heavy. If it’s raining heavy, you have to really take your time I find, I do not trust them in the rain as much.
AR1 our attract Tire for the road. They are also a little sketchy in the rain, but provide phenomenal grip.
For me, the Cup2s took forever to warm up and if they’re not warm, the traction is terrible.
Remember, you can run 265 and 325 on the stock turbo wheels. I think these are the GT three RS size?
Old Mar 31, 2024 | 09:35 PM
gthal's Avatar
gthal
Pilot Sport 4 are not the tires you want. They are a step down from the 4S. Just because a tire is N0 doesn't mean they perform well on your car. If Porsche is building the tire specs for a GT3, they won't be the same as a tire designed for a Cayman. My point being just having the N0 designation may not mean it works well for the specific Porsche model you own. At least that is how I understand it.
The PZero would be comparable to the 4S in my experience. There is also the PZero Corsa. Similar to the Cup 2 in performance but better ride compliance and better in the wet (reportedly) and N rated for the GT3 so likely a decent match for the Turbo.
Old Apr 1, 2024 | 09:04 AM
CanAutM3's Avatar
CanAutM3
Important clarification, the basic turbo and turbo-S wheels are narrower the 991.2 GT3RS by 0.5” in front and a full 1” in the rear. The turbo and turbo-S Exclusive Design wheels are a much better fit, being the same size in front and only 0.5” narrower in the rear. Installing the 325 991.2 GT3RS tires on the basic wheels will cause excessive bulging in the rear and will be suboptimal handling wise.
Richard_Wallace
I would agree the above - the PZero is similar to the PS4S (or new 5S) - the PZ Corsa is similar to the Cup 2. PZero would be my choice. I also thought Good Year had a sports tire (my 992 Targa 4S has the good year) - I thought they had one for the Turbo/Turbo S as well (maybe I am mistaken).
I have the Cup 2s on my GT3 and Mclaren, they are awesome when warm or hot out and dry. But I am going to switch them both to PS4S when done (Though neither of them have the certs for each OEM) - Most of my buddies run the Mercedes PS4S on the 720s, and do a non-branded on the GT3s. So you don't necessarily have to have porsche branded on the car. Yes I hear people that if not might be terrible handling, etc. But likely not if all 4 are done at the same time.
Old Apr 1, 2024 | 09:55 AM
reddsektor's Avatar
reddsektor
Could someone explain why maybe the OP couldn’t just go with 911 Carrera S - PS4S spec tires? They are very wide, in fact the 305 rears are the widest I’ve seen for any 305, 315, or 325 tires. And the PS4S is a better tire than the Pzero.
Per TireRack:
OEM Pzero for 992 TT
Front: 255/35/20, tread width 8.5”
Rear: 315/30/21, tread width 11.2”
PS4S for 992 S spec
Front: 245/35/20, tread width: 8.7
Rear: 305/30/21, tread width: 11.8
