Dakar tires on regular 992
Part number: 992 044 602 AFront axle: 8,5 J x 19 RO 52 with 235/40 R19 96V XL M+S tyres,
Rear axle: 11 J x 20 RO 66 with 295/35 R20 105V XL M+S tyres.
The 19/20" dakar is
Front axle: 8.0 J x 19 RO 38 with winter tyres 245/45 ZR 19,
Rear axle: 11.5 J x 20 RO 68 with all-terrain tyres 295/40 ZR 20.
On the front, you are probably good. Only +15mm difference in diameter on a 1/2" narrower base. On the rear, you have a wider base but only +7mm difference in diameter. So, the answer is "I don't know".
That said, if you have PCCB's, you are SOL. If you have PCCB's, the 19/20" will NOT fit over the brake calipers.
Sorry I couldn't be more helpful
The dakar wheel would look suspect on a cab.
https://www.suncoastparts.com/product/sku992daksr1.html
or
https://www.suncoastparts.com/product/sku992daksw2.html
I would suggest Michelin Pilot Sports AS or similar. Would give a great ride (obviously you give up handling) if that is what the OP is looking for. Any ultra high performance all season tire will do.
Standard C2 suspension ride height is 141mm without Sport suspension. The Dakar is down as having 161mm ride height. 50mm more that a C2 with Sport suspension.
Looking at the C2 19/20 inch wheels with the 235/40 /19s front and 295/35/20s rear , the diameters for the wheels are 27 inches at the front 670mm and 28.6 inches at the rear 714mm.
The Dakar on 245 45 19s front and 295 40 20s rear has a diameter at the front of 29 inches and at the rear the wheel is 28.1 inches.
That means that if they fit, Dakar tyres would raise a standard C2 from 141mm to around Dakar ride height. Suits me fine.
I might have a go, might knock my speedo out a bit though.
Yesterday, I rode in a Dakar w/ the wheel/tire set up mentioned in post. Very stiff suspension and significant noise. IMO, 4 GTS with current Michelin Alpin winter set up far better for winter driving, Pilots for summer
Would love to hear from everyone about recommendations for aggressive 20-21 tires which give more of a Pirelli Scorpion look.
The note off this website says the inside of the front alloy will be 20mm further away from the suspension and will poke out 7.7 mm. The rear alloy will have the inner rim 8.3mm closer to the suspension and also poke out 4.3mm. One thing I would like to find out is whether there is any problem with clearance of the brake calliper along with, is there 10mm + of space to the rear suspension as standard to allow this change. Or is it best to look at third party wheels with a different ET could avoid the rear inner getting closer. Front and back with the AT tyres you gain 15mm in ride height, so clearance with wheels straight and full lock needs checking too. Then with the speedo reading 60mph on the standard wheels on the Dakar alloys and tyres would read 57.5mph and at 30mph they read 1.3mph less. I would be interested to hear how you get on. l, this new wheel will have an inner rim which is 20.4mm further away from the suspension strut. The outer rim will poke out 7.7mm more than before.
