School me on winter wheels + tires (992 GTS)
Are the prices on Tire Rack for the Michelin Alpin 5s correct? Didn't realize the rear tires would be $717/pop.
Since some of the OEM 20/21 packages are available for $5,500, it might make more sense to just grab the whole kit and caboodle...
What are best options for 992 GTS with CL wheels?
The brake caliper clearance is really tight on my GTS with the 20/21 winter set from Porsche, I don't think the 19/20 set would fit.
The tires that came on mine are Michelin PA5's, which have been great in both snowy and slushy conditions.
Premium Sponsor
pilot alpin 5 or continental 870P
Fast FREE Worldwide Shipping FedEx/DHL | Secure Payments + PAYPAL
DISCOUNT CODE:RENNLISTER (5% discount on all items over 600eur)
Weissach magnetic paddles reduced to only 549eur
Website: https://protechpartseu.com/
https://www.dealertirecenter.com/app...20,305%2F30R21
Haha. That sounds like what I'll be doing soon.
I think I will pick up an OEM wheelset wheelset and do the wheel swap at home. I've never swapped wheels before, but figure this is a good excuse to learn.
Question for those of you who handle your own wheel swaps: what do you do about alignment? How often do you perform one, if ever?
I also live in Colorado, but was struggling to cope with spending $3,200 on just wheels. I ultimately decided to buy the 19/20" wheel + tire set from Suncoast, which cost me about 4k with shipping. I very much would have preferred to choose my own tires, rather than get whatever Porsche ships. Tires are all different, and are good at different things. If you're running around around town in Boulder, (in my opinion) you will primarily be dealing with dry, and some icy conditions (from the leftover snow that melted and froze over). There's definitely a fair bit of fresh snow, and a little bit of wet. Looking at Tire reviews, I personally would have opted for Hakka R5's, but they don't make them in 20", so that's a no go. Continental VikingContact7 seem like they would be good here as well, but I didn't see the proper size here either, but I'll admit to not being fully versed in tire sizing. Conversely, the Continental WinterContact TS870 seem to be excellent in the cold dry and wet, but aren't great in the snow and ice that we typically see.
If you're going into the mountains, the biggest concern is going to be snow depth. CDOT is very good at clearing the major highways, but you could definitely get stuck in a snowstorm. It's just constantly snowing up there and I've definitely had to crawl out of Winter Park in our Macan through some fresh powder. We've done a yearly multi-night ski trip in February, and I feel like every day we're waking up to fresh snow on the cars and streets. Usually it isn't bad, but I'd be nervous about getting stuck. However, because of the constant snow, and the temperature, the snow is dry. It's very powdery and soft, and so any tire that's good in snow is great. Like Doug mentioned, Siberian won't miss an opportunity to promote Nokian Hakka 10's (studded) tires, as this is probably an awesome environment for them.
Now to change your own wheels, you need
- Low profile jack (Harbor freight makes them)
- Hockey puck (seriously)
- Wheel stops (I don't have these, but they look ok)
- Impact wrench https://www.homedepot.com/p/RYOBI-ON...65K1/320033027 (I think that is the one I have)
- 19mm Metric wheel socket - with protection
- Torque wrench
- Wheel hangers
and without going into too much detail (cause I gots to get back to work)
1. Set parking brake, make sure car is in gear
2. Block front wheels
3. Put hockey puck on jack, jack up car at jack point (it has a hole in it, there is even a special tool to go in there and center it if you want)
4. Remove 2 studs - you will need to put impact wrench on speed III - don't ask how I learned this
5. Put wheel hangars in
6. Remove other 3 studs - you will need the key for the anti-theft one - that is in the frunk
7. Pull wheel off (pros will tell you that you should have the car on a real jack stand, not the jack - this is correct, so if you are doing it this way, do not put any part of your body under the car)
8. Put new wheel on (it will glide on because of the wheel hangars (I did 25 years of changing my own tires till I found out about wheel hangars. Ugh... magic I tell you, magic.)
9. Hand thread 3 lugs in (start them then twist in -
10. Remove hangars - add last 2 lugs
11. With wrench, tighten lugs - nothing crazy! The car is in the air But it will be resting on these so they need to be a little tight.
12. Lower jack
13. Torque lug nuts - 160nm I believe is the right setting...
14. Continue with other 3 wheels
15. Put proper air pressure in wheels (check the manual, every version of the 992 is different and event the wheel sizes are different - sigh...). Remember there are two optional pressures - full load and I think half load. I do the half load.
16. Put everything away (great time to put a label on each wheel), clean up, start car, reset TPMS (I like comfort pressure, but I'm a wimp), go for drive.
17. After drive, you are supposed to re-torque wheels - maybe a week later. I believe this is optional (as in Doug does not do it ).
18. Wash the old wheels - dry them, have your 20 year old son take them to the basement. Drink a beer or bourbon.
The following 4 users liked this post by doug_999:
Only dealers tend to push the alignment thing. That said, it is important to mark your wheels left and right when you remove them. Don't swap sides of the car, even if the tire allows you to - in fact, for the longest time BMW recommended against tire rotation because after you do that, the tires can act funny for a while - and that funniness might happen while driving in a crazy situation.
Doug, thanks for the link for the wheel hangers. I just swapped out my summer's for winter's. Complained to my fiancé that I was never more beat up than swapping out those tires. 20 years of racing Miatas and changing tires 2 to 3 times a day spoiled me with their light weight wheels and wheel studs. Trying to line up the holes while balancing on those little hub fingers was a total drag. I'm now all set, in a few months, to switch back to summers without breaking my back and frying out my thighs!
