Error Msg Question?
Old Oct 6, 2023 | 02:27 PM
Bobshiv's Avatar
Bobshiv
Default Error Msg Question?
2020 992 C4S 12,000 miles, while driving an error message popped up "Engine output reduced. OK to drive. Return to shop."
Hours later after shutdown, restart and no message. What might that be?
BS
Old Oct 6, 2023 | 03:26 PM
tomtomtomtom's Avatar
tomtomtomtom
do a search!..failed high pressure fuel pump seems a likely candidate.
Old Oct 6, 2023 | 04:17 PM
Bobshiv's Avatar
Bobshiv
Yep...I've done many searches. Fuel pump is suggested but not often, and not as intermittent failure. And seems more frequent in other models (Macan & Cayenne). Others have pointed to bad fuel, overfilled oil tank, loose oil fill cap. In my case, I have "tested" a few times since, up to 8,000 rpm and the message has not reappeared.
So I reckon a trip to Porsche, I was trying to avoid because I'm a long way from the nearest.
Thanks for the suggestion.
Old Oct 6, 2023 | 05:30 PM
Dan006's Avatar
Dan006
BS
a lot of faults appear on the pcm and disappear on the next startup. I think you shouldn't panic
Old Oct 6, 2023 | 05:55 PM
reddsektor's Avatar
reddsektor
Happened a couple times on my 2020 C2S. But never came back. Probably gas
Old Oct 6, 2023 | 05:58 PM
Bobshiv's Avatar
Bobshiv
Thank you. Glad to hear that.
Old Oct 6, 2023 | 06:01 PM
991.1 Guy's Avatar
991.1 Guy
Get someone to read the stored codes. There will be something in the log if you got an error message.
