Quickjacks and 992's
Received 4,192 Likes
For those of you that own Quickjacks for your 992, what model did you buy and can you use it on larger vehicles as well? I have both my 992S with PASM (lowered 10mm), a Macan S and. Cayenne GTS, I'd like to get a unit that will fit under the 992, yet also lift the two SUV's. Suggestions?
(I'm not interested in a twin post or mid-rise lift system)
was doing research on this exact topic today. i would also like to hear some real-world experience. i have two honda pilots i would use it with in addition to my 992.
this is what i have found so far. says it can handle suv's: https://www.lowes.com/pd/QuickJack-7...B&gclsrc=aw.ds
Might want to check this out. You can use the taller lift blocks on the SUVs to get more lift height too.
Quickjack lift question: - Rennlist - Porsche Discussion Forums
I know the current 7000 series would be better for the SUV's, but its 1/2" higher when flattened out vs the 5000 series. I'm not sure if that 1/2" will make a difference, but my car is fairly low with the factory PASM.
I have the 5000 pound unit. One block takes care of the 992. I also use it for an MDX. Just add more blocks.
I have the 5000 unit and one block does the 992. Haven't used it on anything else. The spacing was too short for my Blackwing though. Be sure to measure between the lift points of your longest wheelbase vehicle. I think the 5000 series is ~70 I believe then they make a longer version that adds 1/2 foot or so.
It's really simple to use and about 10 minutes to set up tops. Makes oil changes way easy as well as exhaust or cat work.
I have had the 5000 lb. original unit for about 5-7 years. Have used it on 997, 991, 981 and 992. My 992S has SPASM and it clears the racks. I also lifted my 2015 and 2023 Tacomas with truck lift kit. Also used it to lift wife’s 958.2 Cayenne with extensions bought from Home Depot on sale. The lift and extensions are used sideways on the Cayenne. It struggles to lift the Cayenne but will do it. Also used it on daughters Nissan Rogue and a Toyota Camry for what it is worth.
I am getting my moneys worth out of this Quick Jack.
drcollie (10-03-2023)
The following 4 users liked this post by mksz51:
The shipping kills me...IF they even ship at all...![soapbox](https://rennlist.com/forums/graemlins/soapbox.gif)
siberian
siberian
It looks like I would have to buy the 6000 series unit to make it usable on the Cayenne. The trick of course is not to get one so large I can't use it on the 992. Some time with the measuring tape comparing the distance on all the jack points is in order.
Costco had a hellva deal on the 7000 series, but are currently sold out. https://www.costco.com/quickjack-700...100833767.html
Fullyield (10-04-2023)
