Courtesy lights
Old Sep 26, 2023 | 10:40 PM
Stock718's Avatar
Stock718
Default Courtesy lights
Can someone explain the difference between the courtesy lights included in the Premium Package (Power Folding Exterior Mirros Including Courtesy lightning) versus the "Porsche Logo LED Door Courtesy Lights" you can select in the configurator under the "exterior" sub menu?
Old Sep 27, 2023 | 01:35 AM
NickM's Avatar
NickM
The Courtesy light with premium package lights up all around the doors/ground when you walk up and comfort access detects the key (or i assume you press the unlock button) The porsche logo is simply the logo that requires Opening the door to see.
Old Sep 27, 2023 | 06:50 PM
F8Driver's Avatar
F8Driver
My configurator says the premium package includes ambient lighting, not courtesy lighting (which I think is standard giving some lighting as you open the door). The ambient lighting is color selectable and is in the footwells, doors, etc. I cannot find a reference for "Porsche Logo LED Door Courtesy Lights," but there is an under puddle light option which projects the Porsche logo on the pavement under the door sill when the door is opened.
Old Sep 27, 2023 | 07:02 PM
ABSFlyer36's Avatar
ABSFlyer36
The puddle light, which also is a Red - light can be seen when opening the door, so if the door is open, it can be detected. This also shines a white light onto the ground from below the door. The Porsche LED Puddle light - spells out "Porsche" . This is an easy DIY upgrade if you want to do yourself later. Here is a youtube on a different model
