Appropriate labor cost for 992 lowering spring install?
What’s a reasonable labor charge (in the USA) to install KW HAS springs on a 992 with FAL, RAS, and PDCC? I’m still getting used to everything being more expensive for the 992 versus other older PCars I’ve owned in recent years.
the FAL/RAS/PDCC probably make things a little more complicated, plus HAS have to be height adjusted versus fixed springs, so I’m expecting some additional labor charge.
Having actually installed coil overs on a friend's 992 with RAS but not PDCC or FAL, I would say $1500 with alignment is a bit high but isn't outrageous. It's in the ballpark.
