Dark / insufficient frunk light - is there a solution?
Has anybody come up with a mod to improve the light situation in the frunk?
So I removed the reflector and added some aluminium tape as reflector inside the black plastic box the SMD sits in to throw more light out. Again this somehow worked but there just seems to be just not enough light energy to begin with. Also I noticed the plastic trim the light is installed in is pointing slightly upwards which does not help spreading light into the frunk and even blinds in complete darkness. Really low effort solution by Porsche.
I figured out that this light unit is a standard VAG part used as interior light, glove box and trunk light in VWs, Audis etc.
LED 4E0 947 415, example: https://www.ebay.co.uk/itm/153738666...YAAOSwlTld3DwA
Now I found these and might give them a try:
https://xenons4u.co.uk/4b0947415a-le...ght-units.html
18 SMDs instead of 1 probably should do the job.
Why am I so obsessed with that little light you might ask? Well, the way the lights are arranged in our garage leaves the front end of my car in darkness. I use the frunk a lot for all kind of stuff, so I need to see what's where.
Have you considered adding inexpensive light fixtures to your garage and replacing the ones you have with higher output units? I added a hanging shop light to light a dim area and powered it from one of the existing light fixtures via an adaptor so that it would turn on/off with the light switch. The shop light has LED tubes which draw very little current and aren't sensitive to cold like florescent tubes are.
And then I replaced the existing light bulbs in the two old style fixtures with these marvelous adjustable super bright LED products from Costco.
Continuing my obsession, I replaced all the incandescent bulbs in the garage door opener housings with 100W equivalent 5000K "daylight" LED bulbs that draw only 13W each and run super cool. I turn those on when I need even more light to work by.
The total cost of these lighting improvements was under $100.
The ordered 18 SMD light works great after some minor adjustments to fit it properly. Looks OEM and is as bright as you'd expect it to be. Tried to take a picture but iPhone 14 has major image post processing and I couldn't take a picture in time that looks the way it looks IRL.
@InfiniteSmiles I'd be very interested in knowing what you ended up with! Keep us posted.
