C2 vs T build, need help
- I wouldn't prioritize LSD unless you're doing motorsports.
- C2 is the better car for you. I have a T. It's very loud in the cabin (thinner glass and insulation) and your wife and daughter may hate it on the roadtrips you plan on taking. Suspension may be stiffer also (haven't driven a C2 but T has sport PASM).
- all C2s are PDK.
All of the above notwithstanding, you are right that a T allocation may be easier to get than a base allocation. T is a limited run bu they don't say up front how many they plan to build. It's a 23/24 model only at the end of the 992.1 production run.
Good luck!
this was the thread I was reading up on. Sounds like they got it working better than the factory setup. Im not sure why the PDK has a different rear end except gear ratio but it sounds like the PTV system works with the factory LSD. Either way, it sounds like its possible. The other option is finding a S differential that uses a PDK system so you know it works.
If I like the experience, I'll probably call the other dealer to cancel my wait list and get a refund. I kinda didn't like the vibe the guy was throwing off, he didn't seem to think I was serious and was calling me while I was test driving the GTS to 'check in'. Maybe due to my age or I wasnt dressing fancy enough for him?
Also he wasn't very helpful with talking about options so I'll ditch him for peace of mind. Don't want to risk ordering 2 cars
. Can barely afford a single.
I also drove a 992 GTS in Aventurine Green the other day and I loved it. It was really low so it scraped a little getting out of the driveway.
The concerns about the T would be the ride height, ride harshness and cabin noise. How does the ride compare to a GTS? Is it just as likely to scrape? From some research, the cabin noise won't be that big of an issue and can be likely solved aftermarket if it's a real problem.
C2 is a very comfortable and quiet daily driver over all but the worst roads. Road surface does seem to have an exponential impact on cabin noise however; that's the only way that I can explain the noise issue with the C2 in Harry's Garage (unless the tires were inflated to Full Load pressures). The ride height and suspension tuning does a great job soaking up both highway and mountain road imperfections, and the sport suspension setting does a great job buttoning everything down during enthusiastic driving on well maintained roads.
14 way vs 18 way are very much body dependent. 18 ways get a lot of love here but i've got wide shoulders and hips and prefer the 14 ways. Sit in both if possible. If you can only sit in one, search through some of the threads on here because someone measured the differences between the two and that was helpful to me before I got a chance to try the 18 ways in person (may not help with the lumbar support comfort though).
Burbles are pretty muted in cabin with the windows up on a C2 without PSE. I skipped PSE because of the reviews I read and my desire for quad tips but part of me regrets that decision after finding out that M-Engineering can fix the big issue with PSE (closing the valves between 1k-4k rpm).
Lack of LSD is a non-issue for me driving 7/10s in the mountains with some posted 15mph switchbacks. There's an occasional half second stutter in the rear (not sure if engine is cutting power or stability control is grabbing a break) if I punch it too hard coming out of those switch backs but there's never a loss of traction even in the wet (ignore Nick Murray's opinion on this) and it doesn't even occur if I am smooth with my inputs. It adds some character to the car if anything, assuming that this is due to the lack of LSD. Don't get me wrong, I would have LSD on a C2S if that was an option for me, like the poster above.
PDK is an awesome solution for a car splitting duties between daily and fun car so ignore the haters in this forum. MT cars will have higher resale values though.
I would be a little concerned about the noise levels in the T for a daily driver as well as the issues people are having with the lightweight glass option.
. Can barely afford a single.The Best Porsche Posts for Porsche Enthusiasts
Will talk to the SA about the details tomorrow to get more details and try as many things as I can.
I feel like the glas and cabin noise can be fixed if they are truly real issues for me. Get normal Carrera windshield glass, dynamite insulation. But most likely will be fine without modification.
Any and all trim level allocations are hard to get, but then factor in which trims the factory is currently favoring and it makes certain trims all that much harder yet.
I welcome you to prove me wrong. In fact, I hope you do, as I own a '23 base carrera.
. Can barely afford a single.Keep your names on both regardless of the vibe the SA was giving you. Get whatever you can get first. Allocation can come next week or next year.
Have you driven a C2 or T? You drove 911S and GTS, both are higher HP than C2 and T. You should drive a C2 as well to understand the power and torque. With that said, there are plenty of threads pertaining to C2 base vs S with the consensus base is plenty so..... you should be okay.
