I am looking to get a replacement for that small inner triangle trim on the A pillar/Door Glass that also holds the alarm LED. I broke a tap off after taking my door panel off one too many times. I searched and can't find the part number. I know, I can go to Porsche...but hoped I can just order online and be done.
Passenger side: Abd. Spiegeldreieck L 103790962001 07S which is just the Black triangular housing.
The Alarm LED Insert has the tabs on it is P/N: 992.868.441A Again, these are for the Passenger side door panel
Thanks - problem is when clicking on that part number it then shows "no products found" - when searching online generic the part below comes up instead (door handle trim).
@Tobeit Finally someone with my same problem of needing that part.
I broke mine trying to install an accessory wind spoiler a year ago and still cannot find the part (none of the numbers on this thread work for me in searches either despite the PET looking right).
@FunnyBoy Just to check I, did just order your find - 992-837-307-A-OK1 so will see if that’s it.
However, while not perfect, I fixed mine with a metal piece (can’t recall what it was from but it was just an 90 degree bent piece of metal lying around) and some epoxy that worked well in the gusset.
Doesn’t rattle (and it is much stronger) but I’d still rather have an OEM part, so if someone finds it orderable I’ll be very appreciative.
