Speccing a 992 GTS - Question on PDCC+RAS
Old Mar 14, 2023 | 08:51 AM
Colt_45's Avatar
Colt_45
Originally Posted by jlegelis
Let's play a fun 992 'technology' game shall we?. Here's a quiz, spot the similarities...
  • VTG - (Active) Variable Turbocharging Geometry
  • PASM - Active suspension
  • PADM - Active motor mounts
  • PSM - Active stability management
  • PTV - Active torque vectoring
  • PSE - Active exhaust
  • PDLS+ - Active headlights
  • VarioCam Plus - Active valve timing and lift
  • RAS - Active rear steering
Notice a pattern? The notion that deleting RAS makes the 992 more 'analog' and has 'less nannies' is simply absurd. Porsche's entire engineering philosophy for the 992 is to expand the performance envelope via digital enhancement of mechatronic systems. Which of the 60+ separate controllers and tens of millions lines of code should we delete to make the experience more 'pure'?
You want 'analog', go drive an Elise.
Ignoring for a minute that your list is a bit suspect, if Porsche introduced new “tech” that turned the wheel for you, would you spec it? Porsche would guarantee it makes you faster at the track and safer in the streets.
Not every piece of tech is beneficial for what the driver wants. The fact that other tech exists on the car doesn’t take that away.
But I suspect you knew that since you left off PDCC and PDK, two pieces of “tech” that many owners opt out of because they don’t think it enhances the driving experience.
Old Mar 14, 2023 | 09:11 AM
aggie57's Avatar
aggie57
Yes, there is a pattern here. Some of those items are standard, some are not. Using your argument every Porsche would be fitted with every option otherwise it wouldn't really be a Porsche.
Old Mar 14, 2023 | 09:12 AM
Stephen Shi's Avatar
Stephen Shi
Just think about why pdcc is not on GT cars
Old Mar 14, 2023 | 09:49 AM
Fullyield's Avatar
Fullyield
Porsche marketing’s goal is to sell options to make a profit. So, it will “highly recommend” every available option including leather sun visors and fuse box covers. That’s its job. So, the fact that a Porsche related entity is recommending something needs to be taken with a grain of salt because it is a highly biased assessment and opinion.
Old Mar 14, 2023 | 09:55 AM
Fullyield's Avatar
Fullyield
Good point. And I further note that a majority of the items on the list are not even standard on the base 992 but only available as options at extra cost to the buyer if wanted. That should tell you how critical they are.
Old Mar 14, 2023 | 09:57 AM
Macboy's Avatar
Macboy
Basically it’s what kind of driver you are but you did not tell us. So maybe you can inform us a bit how you drive your cars so we can give some better advice.
If Porsche thought those extra options were mandatory they would add them for standard (and increase the price). On the GT3 RAS is standard for a reason. The car is made for track driving. If you don’t drive your GTS on track you can skip RAS. Thats why it’s optional. If you drive on the road like on track also spec it. I hated the feeling of RAS especially on slower corners on an 992 S. I loved it on my 4S.
Old Mar 14, 2023 | 10:41 AM
TN_3's Avatar
TN_3
Because it only needs to be one thing, a track weapon. With this in mind, they can tune the anti-roll bars for maximum cornering grip. It is also why so many have stated the ride can be brutal on the road. The base/S/GTS have to be more balanced so its a compromise. PDCC allows it to be both more comfortable and more aggressive when needed.
Old Mar 14, 2023 | 03:05 PM
al_b's Avatar
al_b
This.
So much of the focus is what the cars like at or near limit where we rarely if ever are off-track. Getting seasick due to lack of body roll etc, how much roll does non-pdcc have anyway?
but when pdcc is off, ride compliance benefits are realized…when driving real world style (not at limit) on real world (often shtty) roads.
Old Mar 14, 2023 | 03:33 PM
TuvaD's Avatar
TuvaD
Autocar's perspective:
"Of all the 911 options, this is arguably the most impressive but feels the least essential for a low-slung sports car."
https://www.autocar.co.uk/car-news/f...-variants-face
I didn't spec PDCC on my '22 4 GTS and don't really miss it.
Old Mar 14, 2023 | 04:03 PM
ipse dixit's Avatar
ipse dixit
There is no option on a 911 that is a "must-have" in the truest sense of the term.
Because if there was then the Base 911 would be a flawed vehicle. Which we all know is certainly not the case.
Old Mar 14, 2023 | 04:07 PM
FORENN's Avatar
FORENN
Neither is a must-have option and I would skip both.
Old Mar 14, 2023 | 04:30 PM
TN_3's Avatar
TN_3
I don’t think anyone is suggesting that these options are “must-haves” or “essential”, I think the issue arises when people misconstrue the functionality of the options.
Old Mar 14, 2023 | 04:40 PM
HappinessProcured's Avatar
HappinessProcured
Except they have
Thank you! That's exactly what I was hoping for but couldn't find. Now I'm hoping to find something similar on RAS.
Old Mar 14, 2023 | 05:24 PM
Wilder's Avatar
Wilder
Do you read stuff before you post? RAS is an ADD-ON not something you delete. It is a NANNY the same way ABS is a nanny since it helps you drive the car safer. Everything you ever post on the subject reeks of binary logic, which doesn't exist in the real world, ignorance, and righteousness. You're constantly telling people to go buy relics and in this case an Elise. I'm on Porsche number 12 and many here have owned far more than I. I've also been involved in motorsports for about 18 years which requires understanding of how a car works that you evidently don't have beyond reading **** on the internet. The only decision to make is about where different people draw the line on tech and specifically nannies. Clearly you want all the technology that Porsche has to sell you and probably bought things like assisted steering. I'm on the opposite side of the spectrum. I'm buying a new 911 knowing full well how much tech is in it and I'm choosing not to add more, especially when it's not useful. Live with it and stop putting people down for expressing views that are different from yours. Above I offered the OP my opinion on the drawbacks AND BENEFITS of PDCC and RAS. Sorry you don't like it. You're very welcome to your opinion but f*ck off with your righteous attitude telling people that you're right and they're wrong.
Old Mar 14, 2023 | 07:19 PM
secondtimer's Avatar
secondtimer
Not a must-have but if you like "flat" cornering then it is. I will getting it on mine.
