KW HAS Kit for 992 911 Carrera GTS
Hello All!
I was hoping fellow forum members can help me confirm which is the proper KW HAS kit for the 992 911 GTS. After looking at several sites I only see options to select model designation for base or for a model Carrera S. Can someone please confirm if the GTS uses the same kit? I didn't see the part offered on Suncoast Parts but here are a few links I see from Flat6 and IND:
https://flat6motorsports.com/collect...it-992-carrera
https://ind-distribution.com/collect...ble-spring-kit
IND shows some specific info for the kit with SKU #:
KW Suspensions PORSCHE 911 (992) Carrera S Height Adjustable Spring Kit
SKU: 25371084
Thanks for the help in advance!
SKU: 25371084
I might have found the answer searching on KW website directly. It looks like SKU 25371084 is compatible according to thier website:
https://www.kwsuspensions.com/produc...-25371084.html
bayarea_sb911GTS (03-12-2023)
Basic Sponsor
Yes it will.
We have two in stock for immediate shipping!
https://merakiautoworks.com/products...rera-s-2wd-4wd
-Josh
-Josh
Your #1 Dealer for Aftermarket Performance Products
BC Forged / Soul Performance / Akrapovic / Bilstein / HRE / AL13 / CSF + more
Orange County, CA
Email: info@merakiautoworks.com
Text/Call: 213 394 2886
Website: www.MerakiAutoworks.com
Orange County, CA
Does anyone know the spring rates for this kit?
Basic Sponsor
I don't think it will. It works with PASM and PDCC though.
Can't find it anywhere even on our dealer portals, we can reach out to KW if you'd like.
-Josh
-Josh
Would like to keep the same rate as OEM. GTS OEM rates are almost 1/3 stiffer than the C2S and other models KWs lists.
Don't quite understand how they would also be applicable to the GTS.
Hi, I recently got my GTS with SPASM…what a terrible ride honestly. I was wondering if you installed the has kit and if it made the right quality better? Less bumpy…thx!
I've had the KW HAS for almost a year. I noticed a metallic rattle coming from what sounds the outside right (passenger) rear... I can only hear it with the windows or Targa top is down.
Its only at slower speeds, under 14mph and over larger bumps or things like train tracks.
I haven’t taken it back to the place where they were installed, but I emailed them about it and they said they "first guess would be that it is the right rear sway bar end link."
I just took it to the dealer for my one year service and had them look at it and told them what the other shop said. Since it’s aftermarket suspension, they can’t do much but they did double check everything and tighten everything down.
The rattle is still there, so I’ll take it back to the shop where it was installed, but I’m wondering if anybody else is hearing a rattle like this.
how is the ride quality compared to stock
