Detail spray for ceramic coating
Best I have ever found is G Techniq C2V3...I use it as a drying aid. I wash the car, after final rinse blow excess water off with battery leaf blower then spray 1 or 2 sprays per panel and wipe dry. The stuff is on the expensive side ( but so is your car). I have tried Gyeon Q2M cure but in by experience it took a bit more wiping to get a streak free finish than C2V3...but still overall very good. Avoid anything with "graphene" on the label, it is junk that appeals to the Walmart/autozone customers for some reason.
A few years ago I renovated a 100 year old house in Brooklyn and part of it was fitting out a garage for my car and detailing / other projects. It included all of the detailing essentials, including wall-mounted pressure washer, high output lighting, etc. I've posted some shots of the full project in other threads here in RL (it was a major undertaking with a large structural element), but here is a couple of "after" shots of my work area:
The following 5 users liked this post by brianja:
balucipher (12-01-2022),
Dutch SC (12-03-2022),
ns4w (12-02-2022),
Patriot (12-01-2022),
Tedster (12-03-2022)
Adam's - it's the best and doesn't leave streaks. it also smells so good that I find myself using it more and spraying quite liberally, so I buy it by the gallon
https://adamspolishes.com/products/d...UaAhpaEALw_wcB
For a long time I did ONR washes in the garage as they didn’t lead to water everywhere and nobody would every question it. Eventually I became close enough with my super that they let me use a hose setup of theirs in the corner of the garage to do full washes. I definitely didn’t have a pressure washer setup then.
The following 2 users liked this post by brianja:
