I can't tell the difference with PASM
Old Nov 9, 2022 | 05:03 PM
Cst's Avatar
Cst
Default I can't tell the difference with PASM
I have a 2022 C2 with 20-21" wheels.Everytime I push the PASM button I can't really feel a difference between it being on and off. Anyone have any thoughts? Is there supposed to be a big difference?
Old Nov 9, 2022 | 05:19 PM
colnagoG60's Avatar
colnagoG60
Having spent 3 years modifying PASM settings with an aftermarket controller, I'll go out on a limb and guess that on the 992, Sport and Normal are probably damped similarly for moderate speeds, g-force, and throttle positions. The faster you go, and harder you corner, the dampers in Sport mode will probably stiffen more, and or earlier, than in Normal mode. That, or your PASM button is broken.
Old Nov 9, 2022 | 05:49 PM
aggie57's Avatar
aggie57
PASM is always 'on'. That button just switches the settings, as @colnagoG60 says there's not a huge difference but you should feel bumps and like when in sport mode.
Old Nov 9, 2022 | 05:55 PM
c1pher's Avatar
c1pher
Veteran: Navy
You aren't going to notice much of a difference between normal and sport when driving on nice, smooth pavement. You should definitely notice a difference on bumpy or undulating roads and in corners.
Old Nov 9, 2022 | 06:37 PM
Cst's Avatar
Cst
Here's another question.....is the suspension in a base C2 the same as a C2S without the extras like PDCC,RAS,SPASM options?...would a minimally specd S feel the same as a base C2 on the street and track?
Old Nov 9, 2022 | 07:24 PM
Master Deep's Avatar
Master Deep
I can easily notice a difference on SPASM between settings even on smooth roads. I drive in sport suspension mode daily but our roads are nice and smooth.
Old Nov 9, 2022 | 07:25 PM
Master Deep
Yes as long as wheels and tires are the same.
Old Nov 9, 2022 | 10:35 PM
CO 992's Avatar
CO 992
I used to think the same and then I moved where it snows and roads get torn up and let me tell you I can definitely feel a difference when I hit the button on Colorado roads
Old Nov 9, 2022 | 11:02 PM
rouxeny's Avatar
rouxeny
I have been driving in fairly nice roads and I cannot tell much of a difference. Admittedly, I have not been doing any particularly aggressive driving, am still in first few hundred miles.
