PCM5 Whole Screen Carplay/Android Auto
Old Jan 31, 2024 | 06:47 PM
  #256
alim24's Avatar
alim24
How much does it cost after the discount?
Old Jan 31, 2024 | 07:26 PM
  #257
Shogunade's Avatar
Shogunade
I'm under a gag order. DM me if interested.
Old Jan 31, 2024 | 07:28 PM
  #258
Shogunade's Avatar
Shogunade
Originally Posted by Caliporsche
what made you change your mind? Just curious.
After driving around a bit I realized it'd be burning money as I don't really use my phone in there.
Old Feb 9, 2024 | 11:04 PM
  #259
Pad Bender's Avatar
Pad Bender
Just did the install with Raymond...seamless. Went faster than expected...probably 40 min total on my end.
Obviously a lot of technical knowledge is required to make this happen.
Interface seems so much cleaner as PCM and CarPlay both fill out in the same proportions. It definitely loads faster and im looking forward to the first navigation.
No issues with prompt communication throughout. That is appreciated.
Old Feb 10, 2024 | 10:13 AM
  #260
Jeff Whitten's Avatar
Jeff Whitten
Had this done with Raymond on my Macan GTS. Great company and service. Highly recommend if you’re interested.
Old Feb 19, 2024 | 10:13 PM
  #261
Bluver's Avatar
Bluver
I had this installed in my 2021 CS4, and Raymond was easy to contact with ‘at the elbow’ support throughout the installation process. Even after the installation, he was readily available the next day for a couple of follow-up questions.
The full screen CarPlay works flawlessly, it seems to boot faster and has been rock solid stable. The aesthetic upgrade is like having a new car, and a feature that Porsche should have had built from day one — it makes the stock pre-PCM6 look downright antiquated.
To anyone on the fence, I would recommend it — Raymonds professionalism and expedience service makes the process painless.
Old Mar 19, 2024 | 09:25 AM
  #262
Av8ordoug's Avatar
Av8ordoug
Default Innovative soft
Raymond at Innovative Soft upgraded my 2018 Panamera to full screen yesterday. The process was quick and easy. I'm very pleased with the entire process, Raymond's knowledge, and his help.
If you are going to have this done to your car you will need the following:
-A Specific USB to Ethernet adaptor (Raymond will inform you of the adaptor to obtain.
-An Ethernet female connection on your laptop computer. If your laptop does not have one, then you will need a second USB to Ethernet Adaptor.
-An Ethernet cable (RJ-45 to RJ-45)
-An SD card. Raymond will tell you the capacity. I used a 32 GB.
-An SD to USB adaptor if you don;t have an SD slot on your laptop.
Old Apr 12, 2024 | 03:00 PM
  #263
Shogunade's Avatar
Shogunade
Definitely for sale. Msg me if interested.
Old May 12, 2024 | 10:57 AM
  #264
Shogunade's Avatar
Shogunade
Sorry.
https://rennlist.com/forums/market/1411120
Old May 15, 2024 | 05:57 AM
  #265
taylora's Avatar
taylora
hi
another successful Innovative Soft installation. running on a uk 2020 992c2s, as an android user i was pretty fedup with not being able to use waze or spotify properly.
it took a bit longer than expected - mainly my fault. internet over via a mobile fone hotspot proved problematic for the vpn which is required, and then we got a flat battery. but we got there in the end. thank you
Old Jun 3, 2024 | 04:49 PM
  #266
Caliporsche's Avatar
Caliporsche
Originally Posted by sitetech
Did by self. Takes less than 1h.
$400+ for this task is absolutely insane.
Sorry, but that looks horrendous. Can’t pay me $400 to ruin my car and do that.
Old Jun 3, 2024 | 05:00 PM
  #267
Caliporsche
What looks horrendous? It is Android Auto native interface with absolutely proper resolution. Same as innovativesoft guys doing - https://rennlist.com/forums/992/1324...l#post18633173
still not seeing how yours looks the same as any of those photos in the link you posted. Yours is. It as clean as the professional one. But as long as you’re happy!
Old Jun 3, 2024 | 05:15 PM
  #268
aquanaut's Avatar
aquanaut
Guys are you kidding? Let`s compare:
1. top bar = same
2. left OEM Porsche bar = same
3. Main full screen area = same. Content depends on your system (ios/android and nav app)
Agree, this looks good. If there were good guides/instructions on how to DIY, I gladly would have done it myself. I know the code is out there. Do you have a guide of some kind?
Old Jun 3, 2024 | 05:18 PM
  #269
Caliporsche
1. top bar = same
I was looking at the wrong photos lol my phone loads posts very strange and out of order. Apologies as you’re correct! Looks great! Well done!
Old Jun 3, 2024 | 05:42 PM
  #270
Shogunade's Avatar
Shogunade
Can you post it after I sell mine? Haha
