Matrix Headlight reprogramming revisited
Old Aug 11, 2023 | 11:29 PM
  #226
BillyX's Avatar
BillyX
I activated my matrix headlights this afternoon. But rnlst_log, runbuh, and other rennlist posters deserve the credit. Thanks again for sharing.
My only variation was <Garage-Door-opener-Coding-Values>, whose value was blank. It was also grayed-out, preventing value entry. I'll see if I can get dashboard PCM to accept the clicker signal, instead.
It still gets dark late here, so I just went out for a short test drive. No one flashed my headlights, so I think it's a success. I have Night Vision, but had no pedestrians or deer to test special effects. I'll have a better idea in the fall.
Old Aug 12, 2023 | 10:47 AM
  #227
HOTCHKIS's Avatar
HOTCHKIS
I'm a little confused here. I have a 22 911 Turbo S and noticed when driving at night I see an A in the middle of my headlight icon. I also noticed that my brights shut off when there is oncoming traffic and then back on. Is this the way it is from the factory ?
Old Aug 12, 2023 | 01:38 PM
  #228
mikey94025's Avatar
mikey94025
Yes, that is the way it is from the factory for automatic headlights with high beam assist. Matrix headlights is enabling a fancier way the LED-based operate with high beam (for those who purchased the extra hardware option).
Old Aug 12, 2023 | 07:31 PM
  #229
HOTCHKIS's Avatar
HOTCHKIS
@mikey94025 what is the extra hardware option ?
Old Aug 12, 2023 | 07:56 PM
  #230
GoBlue!'s Avatar
GoBlue!
need to spec in the LED-Matrix Design Headlights incl. PDLS+. It’s standard on the TTS so you have it
Old Aug 12, 2023 | 08:04 PM
  #231
HOTCHKIS's Avatar
HOTCHKIS
ok thanks I have it and have an appointment with Anthony
Old Aug 14, 2023 | 11:22 AM
  #232
SilveR316's Avatar
SilveR316
I took delivery of my 2023 911 GTS the other day, and I drove it for the first time at night yesterday. I'm fairly certain that my Canadian spec car has full matrix lights enabled, despite the configurator saying that they act as a single beam.
When driving on dark roads, the lights seemed to skip around the road and actively avoid lighting up other cars and trucks. Everything around it looked like I had high beams on, but the objects you would not want to blind were dark. I'm assuming this is what it should look like?
Old Aug 14, 2023 | 09:36 PM
  #233
NickM's Avatar
NickM
Same, Took delivery of mine 1.5 months ago, They work as intended despite some Claiming they wouldn't have Full Functionality.
Old Aug 17, 2023 | 11:20 PM
  #234
heyadam's Avatar
heyadam
Are you based in the US of Canada?
Old Aug 17, 2023 | 11:44 PM
  #235
NickM's Avatar
NickM
Canada eh
Old Aug 18, 2023 | 01:19 AM
  #236
Woofman's Avatar
Woofman
Canada eh
Hey, since you're in Canada and I'm in the U.S. and we sort of have a language in common, except for you guys not knowing how to correctly spell words like "color" and "labor", could I ask a question or two about how your matrix lights function?
I had the matrix headlights on my '22 Cayenne coded for full functionality last Monday by Anthony Wong of 99X and have been trying to verify that all available features work correctly.
I assume that I should now have the "encounter light" feature described in a "Canada only" section of my owners manual which says, "The light distribution is briefly changed so that the lane being driven on is illuminated brightly. This draws the direction of vision onto the lane being driven on. The driver is less dazzled by oncoming traffic."
Have you noticed this "encounter light feature"? I've driven on dark 2-lane rural roads with no vehicles ahead of me in my lane for over an hour since Monday and I can't see any increase in brightness in my lane as an oncoming vehicle approaches and passes by me on my left. If you have noticed this feature, does it happen only under other specific conditions?
I also haven't seen the 3-flash pedestrian warning (which requires the Night Vision Assist option) but maybe that has been because the pedestrians weren't close enough to the road edge and/or there was too much light from street lights. If you have Night Vision Assist, have you noticed the 3-flash pedestrian warning happen?
It won't be a deal breaker if I don't have these two features. I'm very pleased with how well the matrix headlights now work. I went for another late night rural drive tonight just for the fun of seeing the headlights dance. I recorded a video with my dashcam on Tuesday night that shows some of the matrix headlights new-to-me behavior and put a link in a thread in the Cayenne forum if anybody on the 992 forum is interested: https://rennlist.com/forums/cayenne-...-enabledo.html
Last edited by Woofman; Aug 18, 2023 at 01:00 PM. Reason: minor grammar corrections
Old Aug 30, 2023 | 06:07 PM
  #237
topherserrano's Avatar
topherserrano
I just had the pleasure of having @atwong1 fully activate my PDLS+ Matrix headlights on my TTS last night with another fellow Rennlister.
I couldn’t be happier with the result, but most importantly, the peace of mind knowing he was present in person as it was performed with a genuine and most up to date PIWIS III, was priceless. Anthony’s Official “Porsche Partner” status, coupled with his background at IBM and in Aerospace reverse engineering was quite impressive and reassuring.
I appreciated how he meticulously explained every step of the process and answered my questions, quelling all of my concerns about the integrity of the programming, as well as the likelihood of the Dealer potentially erasing the coding (extremely small likelihood, ex. New headlights get installed after collision). Regular PCM updates from a dealer will not wipe the activation, unless there is a catastrophic failure or error of the PCM, requiring a full blast of the image to reinstall the program from scratch. Anthony can explain the how and why much better than I can articulate.
I was left with the impression that the process and equipment ($800+ power supply, $38,000 Genuine PIWIS III) he utilizes coupled with his background and familiarity was far superior to myself utilizing a PIWIS clone remotely.
He stresses the importance of being able to provide stable power, on-demand (up to 100 amps on his power supply), to a vehicle electrical system to support module reprogramming, thus preventing potential errors and supporting the health of the battery during the entire process.
Further, I did not lose any functionality such as Homelink, after the activation. Other features available in Germany such as the Comfort Access auto-up/down windows and sunroof via fob button press were a nice added bonus to it all.
Anthony’s passion for Porsches and its community is exemplified through his customer service and attention to detail. I would absolutely entrust another vehicle to him without question.
The functionality of the newly activated feature is next level fantastic and money well spent.
Anthony is a sponsor on Rennlist, further info can be gleaned on his website, 9XX.com
Old Aug 30, 2023 | 07:14 PM
  #238
mthreat's Avatar
mthreat
Thanks for the post... I'd love to know more about his aerospace reverse engineering background. I wonder when he's coming through Austin, Texas.
Old Aug 30, 2023 | 08:31 PM
  #239
jfr0317's Avatar
jfr0317
He's coming to Houston on 9/15 to do my GT3 and C2S. I believe he'll have earlier stops that week in Austin and San Antonio.
Old Aug 30, 2023 | 10:23 PM
  #240
jlegelis's Avatar
jlegelis
Reads like a paid advertisement. What I find hilarious is that under the purported sheen of 'official'-this and 'aerospace'-that lies the core fact that Anthony is merely leveraging uncredited techniques previously created and open-sourced by others on this board. Happy that he's able to make a buck doing so for the less technically inclined, but sure do wish he would acknowledge the work of others and stop spreading FUD that his is the only 'one true way'.
