White stripe on tach not Subsecond Clock
One thing to consider - My 991.2 GT3T has a colored tach and chrono... My 992 Targa has both in black - I did this due to: You will get a decent amount of window reflection on the chrono clock in the windshield. It can be somewhat distracting.
I think you are fine with just the tach and not the chrono - specifically if you are going with the sub-second upgraded version. I think it is a nice subtle touch on the tach, you can easily leave the chrono black and it will look fine.
Staffie Guy (09-10-2022)
dixonk (09-10-2022)
Yojeffo (09-10-2022)
MassMPG (09-11-2022)
I went through the same dilemma as you. I am now leaning towards getting regular clock and making both tach and chrono same color. I do think it looks weird to have them unbalanced. Also saves $1100 bucks to cut the clock so I went with it. The default chrono clock looks sporty. I saw both clocks in real life so if you haven't you should youtube or google. The design clock seems nice a as a concept, which I was intrigued by but may not be as good to you once you see it in real life.
Are You Kiddin' Me?
People keep saying unbalanced.
The tach and the chrono are the only two gauges where you can specify the color. The other gauges as well as the center screen do not get a colored outline. If you get a colored (not white or chalk) ring only on the tach, the standard chrono matches all the other gauges/screens. To me, a colored ring on the chrono looks out of place, because the main screen below it matches a standard chrono or subsecond clock perfectly.
Just look at photos and order what you want. If you can’t decide, flip a coin.
