PCM 6.0 CarPlay isssue
Admin i was not sure where to post so if excuse me if I should have posted in a different thread
My issue is this. When I am listing to music from the pcm radio and I get or make a call using CarPlay when the call ends it doesn’t go back to pcm radio. I have to do it manually. Is this normal? The only time it will default back to CarPlay is if I am using a music app in CarPlay. I hope this sounds right.
That’s Apple’s behavior. Yes, it can be a nuisance.
Apple car play is buggy with 6.0, seems it’s a surprise as to what it does. If you have car play as the desired system for your phone instead of the Porsche system each time you answer or make a call it opens car play then it’s hit or miss getting your music back UNLESS you were streaming music through car play such as Pandora etc.
I gave up and use Pandora through car play so as phone is also through car play it works great.
