Dealer Installed PSE- What a Quote!!
Beachwood Porsche (I live in Cincy, but buy from them). They now know how to do it. I think they will charge 1 hour labor, but easy to do...
If you call Kyle at BW porsche, tell him I told you to give them a call - they were really cool about doing it and said it is a good trick to know!
When I called Beechwood and mentioned Richard Wallace they knew exactly what to do.
Richard_Wallace (03-19-2022)
Did you end up getting Beachwood to do this?
Thank you so very much, wish I had it but apparently not on this one. I will be sure and have it on my new order....
So I did. When starting the car in Normal mode then switching to Sport mode you can definitely hear higher volume. I would say it’s more pronounced at idle and anything less than full throttle. In Sport/Sport+ mode, the valves are completely open. I’m not sure if there is higher volume at wide open throttle, but I would imagine the stock programming has the valves completely open under certain driving circumstances as well (WOT). I wanted the dealer to program one of my dash toggle switches to enable the function but they said it would wipe out any other toggle programming and I have one of the diamond buttons programmed with Homelink so I declined that. They said if I flip into sport/sport+ mode then the exhaust valves are fully open. I drive only in Sport and sometimes Sport+ mode so that was fine with me. I later noticed in the car setup menus that I now have the MMI feature button that enables the PSE program (button with a dual exhaust pipe).
I used to have a GT350R and flipping the exhaust button upon start up was dramatic. This PSE software mod is not like that. There is some volume increase but not nearly the difference my old car had. For about $220, it’s a neat trick and cheap.
