PSI in Goodyear vs Michelin Pilot Sport 4S
The other thread got me thinking and I thought I'd pose a quick question:
I have the Goodyears, and a few months back the fronts were inflated by the dealer up to about 40 PSI. That caused the dash to intermittently make a squeaky sound. That resolved when I deflated to my preferred 32-33 psi
I'm now interested in swapping in the Michelins. Question is, do the amount of PSI on those tires translate similarly to the Goodyears? I just want to make sure I should deflate the Michelins to the same level (32 PSI fronts) so that I continue to have a nice and quiet ride.
Thanks to any tire experts.
You should be good at around the same PSI. In summer I run 30 front, 32 rear (when cold). In colder weather to give myself some room I do 32/34. But they will run similar PSI for both in comfort setting.
Yes you should be fine with same pressure listed in the owners manual. I run comfort setting of 29/32. 40psi the dealer set would be miserable.
Is Michelin PS4S available in 992 sizes now? If so that's great.
