Power steering plus
Old Dec 31, 2021 | 03:20 PM
Curvehound's Avatar
Curvehound
Default Power steering plus
My dealer has a 992 for sale that has power steering plus. I don't like what that does to steering feel (or at least my perception of steering feel).
Does anyone know whether PSP can be deleted? I heard it was just a coding change.
thanks
Ian
Old Dec 31, 2021 | 04:44 PM
PHX's Avatar
PHX
Consensus here on previous discussions is that it can be "un-done" by the dealer. You're best bet is to ask the dealer about it, since you're thinking of maybe buying it from them.
Old Dec 31, 2021 | 07:53 PM
eagle1960's Avatar
eagle1960
I have always been interested in reactions to ps+ since it only reduces steering effort at parking lot speeds. Had it on my 991 but not on my 997 or 992 and really don't notice the difference.
Old Dec 31, 2021 | 07:59 PM
JRW1's Avatar
JRW1
I have it and do not have any issues.
Old Dec 31, 2021 | 08:37 PM
kgs365's Avatar
kgs365
i have it and don't have anything to compare it to but it seems fine and not over assisted ...if i didnt know it was on the window sticker I wouldnt know I had anything different
Old Dec 31, 2021 | 08:58 PM
detansinn's Avatar
detansinn
I have it. Love it. Would order it again.
It’s one of the most misunderstood features on RennList.
Old Dec 31, 2021 | 09:45 PM
Bluehighways's Avatar
Bluehighways
Don't have it and don't miss it. Steering effort at low speeds is quite light and definitely acceptable. Not really sure why PS+ is even an option.
Old Dec 31, 2021 | 10:41 PM
AJ_Tokyo's Avatar
AJ_Tokyo
I live in a large city with lots of tight parking lots and multi-storey parking garages and in those situations Power Steering Plus is a huge benefit (I’ve test driven with and without).
As such I’ve added it to my 992 C4GTS build.
Agree it’s not needed for typical US suburban driving.
Add me to the list of those who can confirm it only affects the steering effort at very low (parking lot) speeds.
My dealer confirmed it can be coded off as it is just a software change, so OP you may want to try for a bit and then get rid of it if you really don’t like it.
Old Jan 1, 2022 | 02:09 AM
Curvehound's Avatar
Curvehound
Thanks for all the helpful replies. Glad to hear that it is likely removable and even if not, it sounds like I would probably get used to it given others experince
thanks again
Ian
Old Jan 1, 2022 | 10:38 AM
aggie57's Avatar
aggie57
agreed. The standard PS setup is perfectly adequate even in tight situations.
Old Jan 1, 2022 | 10:51 AM
dgtarga's Avatar
dgtarga
Power steering plus makes very little difference. No reason to order it, but if it's already installed that's no reason to pass on a car you otherwise are happy with.
Old Jan 1, 2022 | 12:08 PM
Archimedes's Avatar
Archimedes
100 percent this. The difference is minimal and only at parking lot speeds. It has zero impact on steering dynamics when actually driving on the road. Not worth adding or deleting, but either can be done by your dealer.
Old Jan 1, 2022 | 01:13 PM
Richard_Wallace's Avatar
Richard_Wallace
I had no power steering plus on my 992 C4S coupe, and opted for it on my 992 Targa 4S that I just had delivered. You can tell a little difference at slow turning speeds, just ever so slightly easier to maneuver. With the small nature of the 911, you probably wouldn't miss it if you didn't have it. Obviously does nothing over 15 miles per hour as it is deactivated. If I were doing it again, wouldn't likely get it, but it is such a cheap option either way it is not bad or good from that respect.
Old Jan 1, 2022 | 01:38 PM
achilleas101's Avatar
achilleas101
I'm curious to drive a car with PS+, because mine doesn't have it and i dont see why I'd want it. Maybe having RAS helps in those tight turning situations that it offsets any difficulty I'd normally deal with, but my car feels super nimble when I'm pulling around my cul de sac and parking. Or any other low speed situation.
Old Jan 1, 2022 | 04:11 PM
Mr Bean's Avatar
Mr Bean
PS+ ! All this technology! What happened to the lightweight car with skinny tires and oversized steering wheel that didn’t even need power steering?
