Pebbles stuck, best way to extract?
I have had to remove a couple pebbles on each side multiple times. Amazing to me that they can get stuck in such a narrow gap. I wrapped a flat head screwdriver with microfiber towel and twisted it to open the gap as stated above. They came out pretty easy with no damage.
Use a polyurethane trim removal tool to gently open the gap first, then use wooden coffee stirrer to push the pebbles out. If you try to push pebbles out without opening the gap, they are likely being held by the body work and pushing them can cause the pebbles to damage the paint.
Tupper (12-30-2021)
