Battery volts
Old Dec 16, 2021 | 07:09 PM
cg760's Avatar
cg760
Default Battery volts
Recently my car has been constantly running between 14.8 to 15 volts. Is this normal?
Old Dec 16, 2021 | 07:31 PM
bobblehead's Avatar
bobblehead
Mine reached no higher than 13.6.
Old Dec 16, 2021 | 07:40 PM
breny4104's Avatar
breny4104
Normally mine is at around 12.8 V when fully charged. When I brake it goes up to 14.8 (or 14.4). And when the battery is low on charge it will stay up there until it reaches a full charge again. This can last 10 or 20 minutes.
Old Dec 16, 2021 | 08:34 PM
Master Deep's Avatar
Master Deep
same. 13.6 once started and usually 13.1 before starting If I let the car sit for a week. Lithium battery.
Old Dec 16, 2021 | 09:49 PM
Antigravity's Avatar
Antigravity
Premium Sponsor
Yes this is normal especially if the weather is getting colder.... the computer will adjust to a higher voltage to charge the battery better in cold weather.
Also if you have any other electronics on like AC , heated seats and other high draw items the voltage will go up as the alternator is smart and will be told to do this by the computer.
Old Dec 16, 2021 | 09:55 PM
cg760's Avatar
cg760
Thanks.
