See through visor
One of the things I miss from my Touareg is the double visor which not only blocks the sun from the front but has a second one to block the side. I tried to see if I could adapt one from the Treg but not the same construct, design (light not IN the unit) or of course size.
Having said that I'm looking for a pair of see through sun visors (for Macan S and 992). Going through the myriads of models a constant issue is it either doesn't stay up or it falls off. Any ones folks here recommend that you use? Just one of the many little annoying things I wish they had spent a little time designing better. TIA
siberian
siberian
eagle1960 (11-25-2021)
Bump?
siberian
siberian
