PSE sound
Old Oct 21, 2021 | 04:56 PM
harshalp's Avatar
harshalp
Default PSE sound
I saw some comments recently saying that PSE sound improves over time, could someone explain how that works?
Old Oct 21, 2021 | 06:03 PM
Skarz's Avatar
Skarz
I don’t think the PSE exhaust incorporates fiberglass, hence I don’t believe it gets louder or throatier over time. There would be no logical explanation to my knowledge. I suspect it is a somewhat natural thing us humans do, which is to attempt to explain our own “confirmation bias” on options that we spent money on.
Old Oct 21, 2021 | 06:08 PM
harshalp's Avatar
harshalp
Thats what I had thought. I had never heard this before but saw 2 comments in the same thread which said that it would, tried searching for them but couldn't find again, figured I should double check before believing anything, thanks
Old Oct 21, 2021 | 06:10 PM
detansinn's Avatar
detansinn
You’ll notice a difference as the engine gets properly run-in/broken in. Folks with higher mileage 992s can confirm this from experience. I’ve received compliments on how my car sounds and people are surprised that it is stock. Then again, I am coming up to 30k miles.
Old Oct 21, 2021 | 06:15 PM
Tupper's Avatar
Tupper
The mystery remains....
Old Oct 21, 2021 | 06:20 PM
harshalp's Avatar
harshalp
I would consider my car well broken in although I dont have nearly as many miles as you, but I do like how it sounds. Part of my problem is I can no longer remember what it sounded like originally, so I can't confirm, I may record the sound and every 1000 miles or so and see if I can spot any differences, I have some sound clips from that long ago to use for reference
here are the old ones
only one way to confirm, people with PSE need to throw ipads in the backseat and set to recording 🤣
File Type: mov
File Type: mov
Old Oct 21, 2021 | 06:24 PM
por356's Avatar
por356
It sounds better with time because after you've racked up some break-in miles you can finally start to tromp on it.........yup, love that sound!
Old Oct 21, 2021 | 11:32 PM
ipse dixit's Avatar
ipse dixit
It's actually the metallurgy from the exhaust pipes that have "broken in" which results in a throatier sound as the mileage is racked up.
Yet another reason to drive the damn car.
Old Oct 21, 2021 | 11:53 PM
aggie57's Avatar
aggie57
reckon the whole car ‘relaxes’ as the miles add up. A 911 takes several thousand miles to be broken in, seeing one that doesn’t get used much is just sad.
Old Oct 22, 2021 | 01:14 AM
boutrosa's Avatar
boutrosa
so the question is, does the car get broken in over that time, or do you get broken in? (use to the car and understand it better.)
Old Oct 22, 2021 | 01:33 AM
ipse dixit's Avatar
ipse dixit
Not just relaxing, nor is it really being broken in. More like breaking down.
The change in sound and tone of the exhaust stems from the packing that is inside the muffler, which is usually a fiberglass compound. Typically the fiberglass in the mufflers/resonators breaks down some after use and the exhaust may become louder or change tone some.
Old Oct 22, 2021 | 07:37 AM
Il CP's Avatar
Il CP
My cars with GPF have definitely changed after being run in. So have my cars with regular cats. My first car with GPF is my 812 GTS and after about 3000 km and a few days running hard on the Autobahn, the sound has changed significantly. My Pista and 488 opened up nicely after tracking as well.
The exhaust does change, but you need to push the car a bit to get a good effect.
Old Oct 22, 2021 | 02:56 PM
detansinn's Avatar
detansinn
Moral of the story... drive your cars and push your cars.
Old Oct 22, 2021 | 05:28 PM
aggie57's Avatar
aggie57
I'm talking more generally; whatever it is each 911 I've owned has felt better once it gets a few thousand miles on it. Maybe it's the driver getting used to it but my last one took a good 10k (a.k.a. 10,000 kms for imperialists) and this one took 5-6,000 miles.
Old Oct 22, 2021 | 06:13 PM
Tupper's Avatar
Tupper
I still think this car sounds better from the outside than in the cabin. Sadly the weather is getting colder and I can’t drive as often with the top open
