maintenance schedule on new 911
#46
Exactly.
Oil change once/ year
Brake fluid change every 4 years (Porsche says 2, which I think is absurd)
Air filters probably every 4 years depending on mileage. They are pretty accessible, so you could pop them out for inspection and reuse if still clean. But they are pretty inexpensive so you may as well just replace them.
Cabin filters probably every 4 unless you live in/drive in a dusty area
Spark plugs every 4-6 (just so they don’t get stuck via corrosion - few plugs will ever be “worn out” in that time.)
Probably a serpentine belt replacement after about 6 years 60k miles.
Brakes as needed. Mine typically last 75-100k miles.
That’s all I can think of. There really isn’t much on modern cars.
I really think that Porsche charges crazy amounts for service because customers like being able to brag about how expensive it it to maintain their exotic cars. It would be insulting to have to say that you only spent what Honda owners spent.
#47
For those doing their own work, documenting purchases of parts are a must. It doesn't prove you did but neither does a receipt from a dealer prove the oil in there is what is claimed or the work done. At the end of the day it's the trust you have in the person(s) having worked on the vehicle. For everything else there's MC
siberian
siberian
That's why I try to check up on any work performed to the extent possible. If I'm paying out of pocket for parts (e.g. spark plugs), I ask for the old parts back.
#48
I get my old parts back automatically - I do my own work and recycle the old oil by using it for heat in my workshop. ![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
siberian
siberian
