CHECK ENGINE LIGHTS - post here & my recent experience
Hi all,
So I had my check engine light on my C2S has come on twice. 2021, with 1,500 miles. Dealer indicated that it was to do with the fuel cap combined with a valve or some regulator of the fuel line pressure that seems to trip up. They are working on replacing these and I'll let you guys know if it solves the problem.
I'm curious if you guys have experienced this same issue or whether you have had your check engine light come on for different reasons. @BIGWORM could this fuel line pressure issue possibly be the thing that is causing your crickets sound in your other post regarding the sounds you have been hearing? Incidently, the check engine light did eventually turn off after a day or so, almost as if the fuel line issue cleared itself out. Nevertheless the dealer is replacing those parts to make sure it doesn't come back. The master technician I have to say is really good at my dealership.
I have not had anything replaced. I just know my first 2020 911 S did NOT do this. But it had a horrible PDK leak and front end clunk issue. This one has clicked and drone honked at me since day one. I have since given up the fight to figure it out since Ive been to 4 dealerships now.
Originally Posted by Autobacs
@BIGWORM and John, When you had this replaced did your engine have a cricket chirping sound before and once it was replaced did it then go away?
The whole thing took about two weeks. Plan accordingly, ask for a loaner (good luck with that).
If you feel annoyed by this, imagine if or when it happens after warranty.
23k miles and no CELs.
Tupper (09-08-2021)
All,
I may have told you guys that I took my car in for a check engine light that kept coming on. They tested it and received a code P0044200 Fuel Tank System Leaking....fine leak. They removed the EVAP canister and replaced the leak detection pump.
It took about a week for them to do this.
Just drove the car today and the check engine light is on again. This is now a total of 4 times. This getting really old. What should I do?
All,
Or call you dealer and ask them to buy it back. They will. And they will slap some lipstick on it and put it back out for sale with a 20K ADM.
Hopefully you live in California where Porsche seems to roll over on buybacks. Other states it seems to be harder to nearly impossible to get to buyback for the same level of issues -- even with the help of an attorney.
Bigworm....my check engine light is yet back on. I may look into this buyback after all. The problem is that I do love the car. I can see if I can get a replacement maybe. Let me know your thoughts.
Had a check engine light with about 2KMs on the clock. Turned out to be some control module related to the system which heats up the cats during warmup. Waiting a month for the part…good now.
Hi thanks for the information....can I ask whether you heard a lot of clicking mixed with a high pitched chirping sound. After that part replaced, did you hear those go away?
Considering Ive had two buy backs, back to back. I would be really hard for me to say stick it out. And both of mine had other issues than clicking and low rpm honk between 1500-1800. Front end clunks. Blinking parking lights while moving. Speaker rattles. PDK paddles not working. Passenger seat that rattles and vibrates on the highway. So I have lost faith in Porsche on the 992 models. At least on the 2020 models.
