Issue with my 992 carrera 4S
Yep. That's it.
Ok, so we all hear the low harmonic drone in low RPM.
IF you hear that. Do you also hear this clicking in your car?
https://www.youtube.com/watch?v=Bbwt8Zfz85s
Kam992 (09-05-2021)
Peterbadger
I was told this whistle clicking noise was from the particulate filter on my 2019 992S UK spec car and was normal
TTBOMK 992s do not have GPFs in the US or at least through 2022
siberian
siberian
I have the same issue. This noise however only comes when you are in a higher gear and at a low speed and low revs 1500-2000. It never happens in the first gear. So all one need to do is to change to a lower gear and noise goes.
Peterbadger
my car goes in for service and recall tomorrow and I have new noise when cold and moving from 2nd to 3rd through gear on PDF. The noise is a gentle high pitch and short ‘woorp’ sound. It goes away after 5 minutes and you don’t hear it at all if you press on.
What recall? Please include the number associated with it. Thanks
siberian
siberian
My carrera 4S
Hi 👋 folks , I have this 992 since a couple of months > 2nd hand 5.000km . I realized the engine makes a horrible noise exactly at 1500 tr/min in Normal mode. After weeks of investigation porsche dubaï says it’s Normal air Intake > anybody with the same crap sound ? Definitely not normal .. I asked them to bring me a car with similar noise. Whatever they say I am 100% sure this is not normal.. opinion are welcome but I feel it will be a long battle for what is obvious for anyone who will drive the car..
From the TSB attached seems the issue could be a damaged coupling between the FRONT (left/right) brake caliper and hose. Should be easy to check for any moisture around the area and or loss of brake fluid. This applies to 2020/1 992s and 718/782s.
GL, cheers
siberian
