Summer/Winter Tire Change
Thank you all very much for your responses. I would like to ask a related question if I follow the advice of those who say a reputable tire shop should be able to switch my tires. It has been my experience with previous much cheaper cars, that tire shops like to push wheel alignments when they switch tires. Would you allow a reputable tire shop to do a wheel alignment on your 992?
With that being said, a 911 is just a car. I wouldn’t have any issue with a reputable independent doing the alignment.
I do want to echo the other comments here about having a second set of wheels. Repeatedly, removing and re-installing tires on the same set of rims is not ideal for the tires. Plus, you’ll see evidence of changed wheel weights, residue, and even scratches. It’s a good idea to have a complete second set of rims. If you buy an official Porsche wheel set, you’ll discover that Porsche uses different offsets on the winter wheels to keep thrown rocks/salt in the wheel wells — smart.
Just one of the advantages of living in Southern California . . . . my Summer Tires ARE identical to my Winter Tires. Come to think of it, they are exactly the same tires.
I am in the middle of making this decision now. While i see the benefit of an extra set of wheels, I am not sure I can justify the cost. It will take me 6+ years of rebalancing/mounting to make up the difference between getting just tires vs tires + wheels. I also have tire and wheel insurance so even I bang up my current wheels I can just have them fixed. Plus I love the look of my current wheels and not having them on for almost half a year defeats the purpose. Leaning tires only!
I live in the mountains in Colorado. Snow 6+ months of the year. I've had winter to all season and back again tire changes done on 3 vehicles for 11 years. Not a single problem with damage to tires or wheels with the local tire shops. I will continue with this routine with the C4 with no concerns.
I hope to just avoid winter tires altogether. Here in SW Ohio there are probably only 30-40 days in winter where driving on summers would be a bad idea. I have been driving my Z4 every month all year around and just avoid snow or very cold days. The same I plan to do with the C2S Cab.
My trick is to have my local Audi dealer do the swap. Great service, they have the right equipment for 21" wheels and ~30% cheaper.
From the Pirelli website: "When temperatures fall below 45° F, winter tires reduce braking distance by 10% on wet surfaces and by 20% on snow compared with summer tires." What they don't say is that everything is fine in the dry below 45° until you turn the steering wheel and the front end has all the precision and feedback of a set of flat tires. If you want to drive it like a Porsche in the cold, consider the winter wheel/tire set. Though, with snow and ice you might want to take it back a notch on those curves.
On many days in the winter, it may be 35 degrees in the morning when I leave, and warm to 55 degrees by the afternoon. Is the handling of the car compromised when driving with winter tires in temperatures above 45 degrees? I know that winter tires will wear very quickly in warmer temperatures, but my question is what happens to performance-- steering, braking, cornering-- when driving with winters at higher temperatures.
I know there is a lot of passion on this topic. My DD, a M235 Coupe gets a set of winter tries and I drive it in snow and ice as long as I have clearance (4"). My Roadster (and in the future C2S Cab) I am driving with MPSS all year around and in winter dry conditions. As the car is garaged, the tire temperature in the garage rarely falls below 50F. When I drive it, the tires stay even in the cold above 50F. Now, if the car is parked outside overnight or during the trip, the tire temp falls well below and indeed you feel like driving on hockey pucks, i.e. not recommended. Also wet / cold and snow / ice is a no-go on summers.
In my experience, real winter tires (blizzaks, etc) last about 3 winters - 4 if you're pushing it.
