Cabriolet windows
When you open the Cab roof, the windows start to go up if you continue holding the roof-open button for even a moment after the roof is fully open. Is there any way to deactivate the windows from doing that?
Totally a “first world problem” but it’s annoying that opening the roof also means the windows will come up a bit and need to be put back down.
The SmartTop module allows you to change that setting - in addition to a bunch of other benefits like opening and closing the top from the key fob, one touch operation from the interior buttons, etc…
