Test Driving a 992
Lol...same here, only have ever seen 3 passing the other way in traffic in 2+ years in my area and only 1 at a dealership for servicing. Rare in western PA.
i guess depends on where you are located. In my part I see them occasionally , and with some effort , you can do test drives at local dealers. I had no problem getting test drives before I ordered mine
Agreed. It appears to be a consensus of both Rennlisters and pro and semi-pro reviewers that PDCC is unnecessary due to the fact that the 992 has so little body lean to begin with.
The new Bilstein Damptronic X shock absorbers now react within a few milliseconds to load changes, magnitudes greater speed than the 991.
On top of that, the wider track also contributes to less lean in corners.
And then there is the added weight, cost of purchase, and long-term cost of maintenance to consider with PDCC.
Well done.
Well done.
