Michelin Mystique
#31
I think there is a bit of Michelin fever... the Pirelli's that are fitted on the 911 are very good. I would bet you could drive two 911's with Pirelli and Michelin tires and not be able to tell them apart unless someone told you what was on the car. They are quiet, reasonably comfortable, have very linear responsiveness and tons of grip. I'm not suggesting they are better than the P4S but they are so close, it doesn't matter. When I eventually replace them, I'll get another set of Pirelli if they are less expensive. Similarly priced, I might get Michelin's just so I can be part of the hype
Home Run (06-09-2023)
#32
People drink too deeply from the Michelin Kool-Aid jug.
#34
My experience with P zeros is they're decent until they're not. Meaning that they're good when they're new and when they heat cycle they get rock hard and the grip level falls off a cliff. I think the PS4s have grip for longer. YMMV.
I don't know if Pirelli has recently updated the tire compound on P Zeros either as my experience with them was from at least 4-5 years ago
#35
#36
sliding around everywhere on treadless goodyears is pretty fun, are michelins the same way after they get broken in to 2mm tread? might be one casual-metric michelin fails on
#37
Especially when cold, the front tires at or close to steering lock do not track evenly causing one of the tires to sort of skip or hop as the vehicle turned. A known issue occurring only under certain circumstances and not abnormal, but it sure feels skeezy. Like when ABS activates, that pedal feels like you're grinding metal, but it is performing normally. My Michelins have not done this at all.
zuffenluv (06-10-2023)
#38
Adding to all of the facts, speculations and opinions above, Michelin has the coolest mascot!
doug_999 (06-10-2023)
