The tweeters are one of the weakest points of the Bose system, so swapping them out can have a big impact.
Got it! Thank you for the insight. I don’t recall if it was mentioned earlier in this thread, but is the tweeter install plug n’ play and fairly easy to DIY? What’s the cost for the Dynaudio and Burmesiter tweeters?
For the Dynaudio install, the 992 has a plastic bracket which holds the Bose tweeter and this needs to be removed.
The round Burmester tweeters are the same form factor as the Bose tweeters, so these would drop right in without having to remove this bracket.
Here are a few pics of what the Dynaudio install looks like.
I spent some time on your site . I want to add the tweeters in the dash and something to replace the terrible Bose speakers in the doors. Is this what I would be looking at for the replacement speakers for the doors? - Thanks!
Does the Audison Prima AP 8 woofers generate noticeably more bass than the stock front woofers? Or do we need an amp upgrade to drive these woofers properly? Would I get more benefit applying sound deadening to the doors and door card vs. upgrading the woofers? Thanks.
