Went out to pick up take out. Short drive. Parked, picked up, started car again and limp mode.
had to shut off and restart like 3 times before I could get it to go into reverse. Any thoughts about whats happening here? Check engine light staying on now. I came home and rebooted like twice and the light stays on.
Did you order pineapple on your pizza? Maybe that's why it is throwing error codes!...............All kidding aside hope everything clears out and you have no further issues.
Hey Kaylie, even though the battery may seem fine, some of the flags you show will be caused by a battery actually. For example he Power steering and if you did have Rear Assisted Steering are Electric, so if the voltage drops a little because the the battery wasn't fully charged the car will throw a flag because it looks to see that the voltages stay above a certain voltage under load. So the system is very sensitive to voltage fluctuations and the state of charge, or condition of the battery. So you may want to check that first even though all seems fine. The battery or loose terminals are notorious for flags and issues.
Oddly you won't often get a direct battery fault flag.... you get all these other symptoms.
