Small PPF question
Small PPF question
I have full front PPF on my car, but the other day I noticed that at both rear corners of the "frunk" lid, the PPF is peeling up ever so slightly. It's really minor, perhaps only half a centimeter or so.
Anybody with recommendations how to address? It's such a small area that I'm tempted to just cut that portion off and forget about it.
I am guessing from your description that your installer did not wrap the edges (both side & rear) of the frunk lid which would only leave a tiny bit of the "point" exposed, rather than any of the panel edges - correct?. If he (she) took the approach of just trimming the edges at the surface, then the type of lifting you describe is almost always going to happen at that point. I would take it back to the installer & see if they could apply a bit of adhesive, or more appropriately, re-apply the entire frunk lid and wrap the edges which should have been done in the first place.
Good luck.
Good luck.
